Old 09-11-2014, 01:36 AM   #1
1l243's Avatar
Connecting Portable Satellite
Buddy just bought a 2015 26fbsl. The sealer told him he could connect a portable satellite to the outside park cable as long as he had inside tv power booster on? Is this true? I know it's not possible with my rig but mine is a few years older.
1l243 is offline   Reply With Quote
Old 09-11-2014, 06:41 AM   #2
TURBS's Avatar
I'm pretty sure the dealer is incorrect on all accounts.
TURBS
"SABRE OWNERS UNITED"
Old 09-11-2014, 04:50 PM   #3
Booster on and the signal comes from antenna. Booster off and the signal comes from cable. If the line has a splitter on it the Sat probably won't work at all. It needs a powered line and the power doesn't make it through a splitter.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 09-11-2014, 05:24 PM   #4
I connect my Direct TV satellite into the outside park cable outlet and it works. My setup requires the power inserter into the coax. My MH has a dual coax box inside with a short jumper that I just unhook from the top jack and run it to the receiver.
howzball is offline   Reply With Quote
Old 09-15-2014, 11:03 AM   #5
1l243's Avatar
Ok I went to.see my friends new to hauler and it's not a.sandstorm.but a.sandsport. oops. Does have separate sat connection though. Sorry about that
Old 09-15-2014, 04:46 PM   #6
I don't think that will work.
The satellite box powers the LNA. So when you hook up the box to the coax connector it is going to pump power into that line. I am not sure what the control head by the TV will do when presented with power.
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
Old 09-15-2014, 05:10 PM   #7
1l243's Avatar
The wiring diagram shows that that cable comes in from the outside and splits before it gets to the tv boost. One going to tv boost and the other going to a satellite only cable connection.
satellite
