Old 07-19-2018, 03:52 PM   #1
Electrical problems in Sandstorm 2018 5th wheel
We cannot find converter box on our Sandstorm 2018 5th wheel SLR F286GSLR!!!!! Please help!
srtmatt is offline   Reply With Quote
Old 07-19-2018, 04:02 PM   #2
Lights are not working...outlets...etc. We have solar panels and they are fully charged. Any suggestions????
Old 07-19-2018, 04:24 PM   #3
Have you checked your battery disconnect?
uncbearfan is offline   Reply With Quote
Old 07-19-2018, 04:25 PM   #4
Yes! Everything works with generator!
Old 07-19-2018, 04:25 PM   #5
yes! Everything works with generator
Old 07-19-2018, 04:26 PM   #6
Not familiar with your unit. Does it have a residential fridge? Sometimes the inverters only power the fridge.
Old 07-19-2018, 04:28 PM   #7
Yes. It does. Thanks for trying.
Old 07-19-2018, 04:46 PM   #8
Just as confused as you
Scrapper's Avatar
The battery disconnect has nothing to do with the generator. It only disconnects the battery from the converter and other 12VDC items. Also, there should be a resettable fuse between the battery and the breaker/fuse panel in your trailer.
This link will help you understand many of the items in your RV. New to RV's helpful hints
Richard & Jill
Camping since 1989, seasonal since 2000
Scrapper is online now   Reply With Quote
Old 07-23-2018, 07:23 AM   #9
Trobec's Avatar
Did everything used to work?
Trobec is offline   Reply With Quote
Old 07-23-2018, 09:10 AM   #10
Head Rambler
If everything works with the genny, then the converter is good.
The power panel is right under the fridge and the converter should be behind the faceplate covering the power panel. If it's not, then it's likely behind a panel in the front passthru.
Gotta go campin!
5th wheel, electric, electrical, wheel
