Originally Posted by Jukebox64
Well guys I checked every single breaker ,wire connection and voltage switch I could find underneath and inside my camper and still no lights inside even though I could find nothing wrong. Then I noticed two bare wires hanging down from the tongue of the trailer, I traced them up to the batteries and connected to a wire under the trailer. I’m no genius but I know a positive and a negative wire hanging from the battery should not have bare ends next to each other. I took the wires loose from the battery and disconnected it from the one wire it was attached to and went back to check the fuse box again. I found the 30 amp fuse almost melted. I am not sure what the previous owner had hooked to these wires but it was obviously too much. I replaced the 30 amp fuse and everything works perfect.
Hopefully you are saying everything is working to your satisfaction.
I can't understand your description of what was wrong or what you did to fix it. Your explanation makes no sense to me.
You checked all breakers, wires and voltage switch (whatever that is?) and could find nothing wrong. Should we assume you checked the fuses to?
Then you found wires hanging down. (even though you said you checked wires and found nothing)
The wires went to the battery and to a wire underneath the trailer.
You disconnected the wires that went to the battery.
Then you checked the fuses again and found a 30a fuse almost melted.
(the photo you posted that is to be like your fuse box has no 30 amp fuses)
You replaced the 30a fuse and everything works perfect.
I must be missing something, sorry.
