Old 05-22-2018, 03:02 PM   #1
Trobec's Avatar
Fresh water overflow line
Was wondering if anyone out there with a f285gslr could take a photo of where the overflow hose for the fresh water tank is located. Mine doesn't have one and would like to know where about to start my search so I don't have to cut the whole bottom up. Thanks!
Trobec is offline   Reply With Quote
Old 05-23-2018, 06:53 AM   #2
SeaDog's Avatar
You may not have an actual overflow/vent hose out the bottom, check next to the fill connection and see if there is a hole with a screen over it. Just a thought I don't know your actual rig
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-23-2018, 07:19 AM   #3
Trobec's Avatar
There is supposed to be one. If I fill my tank too full it leaks out the underbelly.
Old 05-23-2018, 07:22 AM   #4
cavie's Avatar
fill your tank and see what happens. It should flow out on the ground when full. It will be a clear or white hose with no valve on the end.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-23-2018, 07:31 AM   #5
ben31's Avatar
There are quite a few variants of this, but most work the same way. The overflow is almost always collocated with the fill. In the attachment, the little screen at the bottom left is the overflow.
The hose out the bottom or side (low point drain) is almost always the hose to empty the tank.
Name:	fresh water fill.JPG
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 05-23-2018, 12:33 PM   #6
Trobec's Avatar
When I fill my tank it drains out from the underbelly soaking all the insulation in the process.
Old 05-23-2018, 12:37 PM   #7
Trobec's Avatar
Just for the record, this is my 6th rv. The last 4 have been toy haulers. All of them with had the same fill port as you have pictured as well as an over flow attached to the fresh water tank.
Old 05-23-2018, 01:04 PM   #8
cavie's Avatar
Well, that's a horse of a different color. and not a good color. It should be on one of the sides of the tank. The hose may have disconnected or never got connected in the first place..
Old 05-23-2018, 01:38 PM   #9
Sounds like the overflow hose came off check line from the inside where it fills your water tank
ShickshinnyJoe is offline   Reply With Quote
Old 05-23-2018, 01:39 PM   #10
Another thread?
I believe I read another thread in the last couple of weeks in which it was reported that the overflow hose wasn't connected or was loose or something. Do you suppose the same worker repeated the mistake?
Larry
Larry-NC is online now   Reply With Quote
fresh water, water
