Old 10-23-2018, 08:33 PM   #1
Just joined the sandstorm crew! '19 251SLC
We picked this beast up in az a few weeks ago. We are currently planning some winter trips to try out the Arctic package. Click image for larger version
ID:	189866Click image for larger version
Mcdaniel1991 is offline   Reply With Quote
Old 10-23-2018, 09:10 PM   #2
I'm Lost
Welcome to the forum.
Fab looking "Beast", always take the fork in the road, hang on and
We're off to Killbear Prov Park this weekend but not much of a test for our TT with temps around +2c, snow & rain.
Enjoy the experience.
Geoff & Francesca
2013 F150 Screw, 6.2L gasser, HDPP, LT tyres, Firestone Air Bags, 250L aux tank.
2013 Rockwood Signature 8310SS
wabakami is online now   Reply With Quote
Old 10-23-2018, 09:16 PM   #3
Mslaman's Avatar
Are you sure your in AZ? What is all that grey stuff in the sky?
Kidding of course. Itís been raining here like crazy.
Congratulations on your new RV. your going to love it.
Mslaman is offline   Reply With Quote
Old 10-23-2018, 09:27 PM   #4
I actually live in NM, just found the best deal up in Phoenix!
Old 10-24-2018, 05:16 PM   #5
Tom48's Avatar
We are in Sunny Southern California with the T250 (I think the difference is you have a full queen and ours is shorter) We have never really tested the Arctic Package but the tank heaters are a nice placebo, if you are on hookups otherwise who knows how long the batteries will last "HEATING" the tanks.
Lots of thoughts for you and lots of pointers, but I guess first I will say WATCH OUT FOR HIGH TONGUE WEIGHT. With supplies in the cargo bay and full water, but WITHOUT a big load in the TOY AREA your tongue weight will be substantial.
Oh and I am a believer that proper inflation would make Factory CHINA BOMBS last like real tires. I am obsessed with Tire Pressure and still at about 12,000 miles the first China Bomb blew and when in the tire shop we discovered that one other had a huge bubble on the inside about to blow and a cord separation becoming significant on the another. LR-D tires now all gone, LR-E one Carlisle (my already upgraded spare)and three Goodyear Endurance. Either is massively heftier than originals and very comparable to one another. Used to sweat 65lb cold every trip and now just run those babies up to 75 and +or- 5 lbs I do not sweat it. Big stress reduction for me.
Without Toys in the Back, we normally carry about 800lbs of Hot Air Balloon in the bed or our truck, and the tongue weight pushes our F250 to its maximum cargo carrying capacity. Good thing it is just the two of us or we would be over GROSS on the back axle.
I suggest that before you go too far, load out for your trip with Water and gasoline as full as you plan to pull it and mama/family on board then roll through a CAT Scale. I was happy with weight transfer to the front axle but shocked at how heavy I was, still, on the rear. I immediately moved some of my CARGO like tool boxes, 8 ton bottle jack, etc. to near the back trailer door and it made some difference. Gas is back there so I keep it full now too
Before you load out full BE SURE YOUR WDH is set up well and doing its job.
Then MOST OF ALL HAVE A BLAST.
Tom48
In Sunny So Cal /w
2004 SD F250 now BULLET PROOFED
2017 Sandstorm 250 TH, with
8 wheel TST TPMS and
The Hot Air Balloon RESTLESS
Tom48 is offline   Reply With Quote
Old 10-24-2018, 06:10 PM   #6
Awesome advice, I have been worried about the high toung weight. I plan to add some under mount storage boxes in the rear. Mine came factory with "e" tires so hopefully they last. I plan on adding a tpms. I still need to go to a weight station and check my weights. Also, does yours have a switch for the tank heaters. I have been trying to figure out if mine has tank heaters. I don't have any switches.
Old 11-25-2018, 10:23 AM   #7
Quick question....what toy are you fitting in your camper?
tgale is offline   Reply With Quote
Old 11-25-2018, 11:31 PM   #8
Tom48's Avatar
They had some BS story at the factory when ours special ordered with the Arctic Package came with no Tank Heaters. They claimed there are two levels of winter packages that have SECRET special insulation and enclosed bottom but one has no tank heaters and one has them. We ordered them, paid for them and the factory took if in the day after we took delivery and had it back to us in five hours WITh the Tank heaters and every other little fix I could spot when I took it to them YES they have switches and every one I have seen has the red light on the switch like most Water Heater Switched do. Our year they were on the panel under the frig next to our Breaker/Fuse panel/Charger-converter. FActory warranty dept in Rialto was GREAT but they only take select problems directly and refer you to your dealer for most stuff or if your dealer is not close they send me to an independent repair station in Fontana. Good Luck
Tom48
In Sunny So Cal /w
Old 11-25-2018, 11:41 PM   #9
Tom48's Avatar
Two trips a year there are three Quads that fit in to ours The rest of the time just a few hundred pounds of Junk The auxiliary water tank with 40-60 gals of water behind axles and an exceptionally heavy tongue weight
Tom48
In Sunny So Cal /w
