Old 01-18-2012, 12:17 AM   #1
New 233slc any tips
I am new the to forum and the toyhauler world and was just looking for some helpful tips. I just purchased a 2011 sandstrom 233slc with fiberglass sides, 4.0 onan and some other upgrades clarion speaker system etc. Do any of you have pros or cons for the 233slc. Any helpful tips would be great this is my first trailer and I am very excited to use it but am looking for any type of recommendations. Just waiting for my truck to get out of the body shop, rear tire blow out crazy!!
xjwheeler is offline   Reply With Quote
Old 01-18-2012, 01:07 AM   #2
showtime0022's Avatar
Nice toyhauler!!! I have a 22 Stealth. I would recommend Maxxair vents II. X chocks. Put 10 gallons in fuel tank and pime the pump. Dont use the first gallon from the tank..... It will be dirty.
showtime0022 is offline   Reply With Quote
Old 01-18-2012, 08:34 AM   #3
Jestercyco's Avatar
Nice set-up! We have an XLR 29MBV. Do get wheel chocks and always put a block under the jack. I have the x pattern that go between the wheels and I also use the chocks that go under the wheels. . You will find all knids of good info on this site. You might look at an electric jack. It saves a lot of crancking when you hook up.
Good luck and Happy Camping.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 01-18-2012, 08:52 AM   #4
RubenZ's Avatar
Get some:
Wheel Chocks
Tri-Lynx Leveling Blocks
Maxxair Vent Covers
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 01-18-2012, 03:42 PM   #5
Thanks for the info guys. Got lucky 3 of the 4 vents already have the maxx vent covers.
Have any of you hooked up a inverter for running your electronics like small tvs or laptops? I am thinking about going that route so I don't need to run the generator as offten. What are your thoughts.
Also do any of you know where the water heater by-pass is on these trailers. I was told it has one but I have know Idea where it is.
Thanks again for the info.
Old 01-18-2012, 03:49 PM   #6
Jestercyco's Avatar
Mine is by the water pump behind a panel that you have to pull to get to it.
Jester
Old 03-02-2012, 04:45 PM   #7
We've got a 2010 233slc. You probably want a second battery, we had that installed at the time of pickup. Did you get the screen covers for the back when the ramp is down? If so, be careful when you are putting the ramp back up to make sure the zippers are not in the way. The door will crush them. Also, make sure you do not lower the beds with the couch folded up against the wall.
We bought a real mattress for the front and installed an extend-a-shower shower rod and it made a lot of difference in the shower area.
I like the fiberglass siding, ours is the aluminum.
Matt
2014 GMC Sierra 3500 Denali SRW
2016 Dutchman Rubicon 2905
Deadheadmatt is offline   Reply With Quote
233, 233s
