Old 06-15-2016, 12:46 PM   #11
Turn switch on in trailer go outside and turn on pump with the toggle switch. After pumping gas turn off toggle switch. Not sure why you would want to leave the outside toggle switch on.
guyster is offline   Reply With Quote
Old 06-15-2016, 12:48 PM   #12
northstar1960's Avatar
the fuel station works good . can be hard to fill at the pump found turning the handle upside down helps . then you have the inside switch and the switch out side .turn in inside switch on then go around pull the hose to fill what ever hit the outside switch once that turns pump on then when done hit the outside switch twice and it shuts off the pump from outside
northstar1960 is offline   Reply With Quote
Old 01-22-2018, 01:18 PM   #13
Originally Posted by sandstormfam View Post
Off topic question. Have you used the fuel station yet? This is my first toy hauler with a fuel station and I was wondering if it's working properly. When it's on, the pump keeps running regardless if you're pumping fuel or not. I was wondering if it's supposed to work like the water pump and prime, pressurize then shut off until you start pumping again. The pump is loud inside the trailer, so I usually turn it on, go pump, then hit the emergency shut off switch to turn it off since you can't turn it off at the timer switch. Does that sound about right in your experience? My buddies fuel station seems like the pump is only on when dispensing, but he has a different system.
This is correct for your fuel pump, there should be a cheap on/off switch mounted on the frame by the pump somewhere. I flip my switch inside then go out and turn on pump switch. Fuel up what I need then turn off switch for pump. If thereís not a switch your pump could possibly burn up.
kbmerrowsrp is offline   Reply With Quote
quality
