Old 05-06-2016, 11:33 PM   #31
Very good. Will post later in month if all goes well.
Rodical is offline   Reply With Quote
Old 05-06-2016, 11:34 PM   #32
Randall62's Avatar
K good luck
Randall62 is offline   Reply With Quote
Old 03-31-2017, 12:14 AM   #33
rtaverne's Avatar
Originally Posted by Rodical View Post
I'm trying to pull the trigger on one by the end of the month finally. Not sure on getting the double slide or the single bed slide. I like the single better. Any updates you can report on with your trailer?
ID:	133372Click image for larger version
ID:	133374 I love my Sandstorm. Chose the double slide for extra room. My Teryx SxS fits perfectly and it is a wide machine. Tow mine with a 2016 2500 Cummins using a Anderson hitch and tows like a dream. I've put about 2,000 miles on her so far and no complaints! BTW what demand water heater do you all have installed?
rtaverne is offline   Reply With Quote
Old 03-31-2017, 09:39 AM   #34
Originally Posted by rtaverne View Post
Attachment 133372Attachment 133374 I love my Sandstorm. Chose the double slide for extra room. My Teryx SxS fits perfectly and it is a wide machine. Tow mine with a 2016 2500 Cummins using a Anderson hitch and tows like a dream. I've put about 2,000 miles on her so far and no complaints! BTW what demand water heater do you all have installed?
Mine has the Atwood on demand water heater. Wish it had a tank though. Did the recall on the Atwood but still have had to go out side and reset it a couple times.
guyster is offline   Reply With Quote
Old 04-02-2017, 12:26 AM   #35
rtaverne's Avatar
Mine is the Girard tankless water heater...works great once I figured out how to operate it!
Old 04-03-2017, 06:28 AM   #36
Trobec's Avatar
I have a Girard as well. One you learn that you only use the hot water nob to control the temp it works very good. Pluses you need good voltage.
Trobec is offline   Reply With Quote
Old 05-20-2017, 01:15 PM   #37
Hi rtaverne, do you have any problems towing your Sandstorm with the short bed?
btf66509 is offline   Reply With Quote
Old 05-20-2017, 04:37 PM   #38
rtaverne's Avatar
No...I use the Anderson ultimate 5th wheel hitch
Old 05-20-2017, 05:03 PM   #39
Old 05-09-2018, 03:05 PM   #40
OTH
I know this thread is a little old, but I hope it has a little life left in it. I will be purchasing a Sandstorm F286GSLR in a month, and can't wait. I'm deciding on a hitch for my short bed 2500HD. I'm considering the B&W Companion non-slider, which is capable of a 5" setback if necessary. Based on your Anderson, do you think the B&W would work for me? I'm going to go next week and do some measuring. Thanks
OTH is offline   Reply With Quote
