Old 04-20-2014, 09:06 PM   #1
keefe237's Avatar
Tech help.. not so much a thread.
I'm new to the Forum and wasnt sure where my question should be posted as this area says it for threads? This is the only place i could find to post a little "please help" question.
Here it goes.
We recently purchased a used 2010 3215 srs Sandstorm fifth wheel. While walking the trailer over with the owner, older but very nice, he could not answer a few questions about random toggle switches I noticed on the trailer.
One of the toggle switches is mounted underneath the frame just in front of the fuel pump at the rear of the trailer. I have an on/off switch inside the trailer so I'm not sure what its for??
The second toggle switch is mounted in the front compartment where the propane tanks are mounted as well as the generator if i had one. The wires to and from the toggle switch both run up and go up towards the overhang sleeper then towards the front of the trailer. If the battery is on there is 12v to the switch. When the battery is switched the 12v slowly drains to 0v. I attached photos of this switch for reference. Also i checked under the bed and in the cabinets and nothing is there as far as wires are concerned.
The photo on the left is where the wires run from the toggle switch. Also when you are looking up at the wires, left would be towards the overhang and to the right would be towards the stairs leading out of the bedroom.
Any thoughts would be appreciated.
Name:	Wires from toggle.jpg
ID:	50499   Click image for larger version
Name:	Unkn toggle.jpg
keefe237 is offline   Reply With Quote
Old 04-21-2014, 12:22 PM   #2
Oakman's Avatar
I can't really help you other than bump up this thread. The toggle switch in the picture looks more like a modification that was made by a previous owner. I've never seen a toggle switch like that installed at the factory. Perhaps a Sandstorm owner might chime in and be able to help you.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-21-2014, 01:05 PM   #3
keefe237's Avatar
Thank you. One other thing. What is "bump up the thread" mean and how do I do that. Haven't found to much instruction on the forum.
Sent from my SAMSUNG-SM-N900A using Forest River Forums mobile app
Old 04-21-2014, 01:10 PM   #4
SKnight's Avatar
Whenever someone replies, it bumps this to the top of the recent lists list. That way more people see it. Forum etiquette dictates that you can reply just to bump it yourself about once a day.
I agree, that looks like an add on switch. Can't hear or see anything changing? Have someone that you can put into the bedroom and observe as you toggle the switch?
Old 04-21-2014, 01:20 PM   #5
wyo700's Avatar
The first switch you mentioned is the emergency shut off for the fuel pump for your fuel station. It's for just in case you have a problem while filling a machine you have a shut off outside and don't have to run to the inside. I actually turn my switch on inside and then go out flip the outside switch every time so the pump is not running while I'm not standing their. The other switches I don't know. Sorry
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 04-21-2014, 04:34 PM   #6
keefe237's Avatar
That makes sense. Thanks. As for the second when I shake it I can hear it above my head towards the king pin. Could it be power to the emergency break?
Old 04-21-2014, 04:47 PM   #7
SKnight's Avatar
It could do that, but the only noise you should hear are the magnets hitting the drums at the wheels.
But it's great that it makes a noise, now just a matter of chasing it down!
Old 04-22-2014, 12:48 AM   #8
keefe237's Avatar
Bump
Old 04-22-2014, 03:36 AM   #9
I am not able to you either other than bump. Welcome to the forum.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 04-22-2014, 05:29 AM   #10
Post #1 leads me to prior owner placed/used the front switch to activate the E brakes ,to use as (Parking brakes),a very Big (No No)! The hint is when switch is On the Batt.runs Down. With a (6) brake system that is a lot of Draw. Any switch in the E brake other than the (Pull to Activate) is a Dangerous situation! Youroo!!
