Old 02-27-2015, 06:03 PM   #1
Brushhog's Avatar
Toy lock
Hey guys I have a 203SLC toy hauler and it has a toy lock at the back corner. This weekend was the first time using it and it worked great until I tried to put it away. It retracted about half the cable and then stopped, no matter how much I worked it back and forth it would not retract any more. Do they make replacement parts for the lock? I would like to find replacement parts as opposed to a new one cause it was welded to the chassis when installed
2012 Toyota Tundra Crew Max TRD Off Road
2010 Sandstorm 203SLC
Brushhog is offline   Reply With Quote
Old 05-29-2015, 07:34 AM   #2
270GSLR's Avatar
I have only seen new ones for sale. I don't have one myself and cannot say for sure though.
270GSLR is offline   Reply With Quote
Old 05-29-2015, 07:42 AM   #3
RPAspey's Avatar
Was it like this? If so, good luck finding parts. I bought one and used it for 3 years or so. The cable then failed to retract. I tried to find parts but couldn't. The spiral spring inside rusted then broke. I would like another, but won't because of this design issue.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 05-29-2015, 01:29 PM   #4
270GSLR's Avatar
Name:	ImageUploadedByForest River Forums1432924017.504216.jpg
I bought this its not as covenant but does the job 15 feet locks my 2 dirt bikes and a quad. I run it threw the leveling jack.
Old 05-30-2015, 08:44 AM   #5
RPAspey's Avatar
Originally Posted by 270GSLR View Post
Attachment 78475
That is what I use now. Simple but effective. It always seems to be at the bottom of the tool now when I need it. Thus why I miss the Toy Lock.
Old 06-04-2015, 03:30 PM   #6
Taranwanderer's Avatar
Sounds like you need to buy a new Toy Lock and keep lubing the snot out of it to keep it working right (and from rusting.) It seems like a good idea, but not if it's going to take a dump on you after a few months of use. Lube, lube, lube!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (18)21 (19)23
2016 Ford Fusion Titanium (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 06-22-2015, 05:25 PM   #7
Idafrog's Avatar
You sure it's welded to the frame? Reason I ask is my new TH came with one and it would not retract also. Come to find out the bolts were tightened to tight and "pinching" the housing against the spring. Once I loosened the bolts it zipped right in scaring the crap out of me. I put new bolts on and doubled the nuts and put lock tite on them also at just the right pressure to keep the housing tight but allowing it to retract properly.
2015 Shockwave F33SAGDX Toyhauler
2011 Ram 3/4 ton 4x4 Cummins diesel
Idafrog is offline   Reply With Quote
Old 06-26-2015, 06:38 PM   #8
Brushhog's Avatar
Yeah it looks like I need a new one, and yes it is definitely welded to the frame.
2014 Dodge Ram 2500 Mega Cab 4x4 Diesel
