Old 02-13-2013, 09:40 PM   #21
We may buy an '09 F250 supercab with a V10 this weekend. From what I have read and been told, the V10 is a great engine. But, the '08 and earlier ones appear to have issues with the head because there weren't enough threads in the head to engage the plug threads. The V10 has more power, but less torque. Mileage seems good too.
We have heard of a lot of major problems with the Ford diesels. Head gasket failures and other problems. $7 - 10K in repairs if it hasn't been taken care of. One dealer told us he can't give them away. Maybe the more recent ones are better? We thought about getting a Chev with the duramax engine but the premium is as much as another $10K, depending on year.
Man, the F250s seem so much bigger overall than an F150!
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 02-13-2013, 10:18 PM   #22
dsrace's Avatar
the ones they can't give away are the 6.0 ltre diesels they have a number of issues but nothing that can't be fixed if caught early for $8 to $10k! that's not good just stay away from them. the 7.3's are good and reliable but still have a few upgrades to be done but everyone knows them inside and out! the 6.4 is a good one but you need to get it with 30k miles or less and get the dpf deleted to keep the fuel dilution in the oil from taking out the top end of the motor if you want 400k miles or more out of them. they will actually start making oil and need oil changes every 3k miles not by the dash gauge if you don't delete the dpf which does require new exhaust and a tuner a good tuner. it will run about $2800 for the good parts with labor to do.
dsrace is offline   Reply With Quote
Old 02-14-2013, 12:18 AM   #23
asquared's Avatar
I'm going thru the regen issues w/ my 2009 6.4L f250. It regens and smokes everytime it is rainy and the temp is below 50. It does this fequently, I have seen
3 times in 1 day. It takes my truck 20-25 miles to complete a cycle. It also now has an alternator issue and a leaking rear axle seal. We have owned it for 1 yr and 20,000 miles. We bought it with 32,000 miles on it and can't do the delete/tune or it will void the extended warranty. We are already contemplating trading it on a Chevy or dodge 1 ton.
As for towing, I can't say enough good things about it. Having come from an armada thatwas outmatched by a 7000 lb tt, it is a night and day difference. That said, I'm not currenty a ford diesel fan.
asquared is offline   Reply With Quote
Old 02-14-2013, 05:48 AM   #24
hotrodj125's Avatar
ONly 10K,,,, I pull 12K with my F-250 4X4 6.0 diesel and have NO problem gettin the job done.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
Old 02-14-2013, 06:22 AM   #25
captbenjy's Avatar
To the OP, one thing you should also take into consideration is the longevity of the engine. The more of a load you put on an engine decreases the life of that engine and also increases the chance of parts failing. While the gas engine will do the job, how long can you expect it to do it working at close to maximum output?
I own a 2009 f-250 6.4 diesel which has been tuned and dpf deleted. No problems and I'd drive it anywhere. The tuner also doubles as extra monitoring gauges so I can keep a better eye on temps, pressures etc.. What dsrace was saying about the 6.4 is that it's a great engine. Basically overbuilt by international after all issues of the 6.0. However the EPA got evolved and made them add a DPF which is like a cancer killing a great engine. I could go on and on about the 6.4 and ill be the first to say, if you can't or won't delete the DPF...DON'T BUY ONE! I don't care if you have an extended warranty. With the DPF installed on a 6.4 YOU are doing damage to your engine. The EPA does not care how many miles your $50k truck lasts, it only cares that its not blowing soot out of the exhaust.
2013 Columbus 320RS "The Wonder Wagon"
2009 F-250 4WD (Tuned) "Black Beauty"
captbenjy is offline   Reply With Quote
Old 02-14-2013, 06:28 AM   #26
captbenjy's Avatar
Biggest difference between the V10 and Diesel? First good long grade you pull pulling 10k lbs. or more with that gasser you'll wonder if you should've got a diesel before you get to the top.
Old 02-14-2013, 09:51 AM   #27
Dave_Monica's Avatar
Being the devil's advocate...
I agree that pulling the first steep grade, the difference will clearly show the towing power of the diesel truck. However when towing, I don't see any need to determinely try to maintain speed upgrade, especially on multi-lane highways...just burns extra fuel and saves a couple of minutes travel time. In fact if you were to look at this as the amount of upgrade towing you do, I know that for me it's less than 1% of the total towing. That said, I'm in no rush to replace my V10.
Dave
Old 02-14-2013, 10:09 AM   #28
daydreaming about camping
jeeplj8's Avatar
getting back to the truck OP is looking at:
what kind of miles does it have, condition and price?
The V10 was dropped form the Ford lineup in favor of the 6.2 gas engine. There are some known issues with the V10, as there is with virtually every engine out there.
For most people, simply towing a TT around, the V10 is more engine than they will ever need. It is thirsty, but cheaper. Crunch some numbers and make sure it works for you.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 02-14-2013, 10:37 AM   #29
V10 dropped? It is still sold in the HD segment and is in most gas class A/C motor homes. Great trouble free engine.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 02-14-2013, 10:48 AM   #30
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by Gizmo0706 View Post
Hello all,
I am about to pull the trigger on a 2009 Ford f-350 CC dually 4x4 with the V-10 engine. Does anyone have anything good/bad to say about this vehicle? We will be pulling our Coachmen 28dds which is about 7k loaded. I know fuel mileage will be terrible, but it will not get many miles other than when pulling the camper. Thanks!
Not a Ford guy but...
IMO, the V10 your looking at will tow so much better than the Tundra you use now, especially with only 7K lb loaded camper.
Also, if you do get the itchy finger to purchase a larger TT or lightweight fifth wheel, the V10 will be well served.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
f-350
