Old 09-27-2015, 07:10 PM   #21
dcheatwood's Avatar
Originally Posted by wmtire View Post
That's what I was thinking, since any battery powered shaver is actually DC voltage. However, I guess if you were without 120 volt power for a long time, then you might not be able to recharge the battery(ies) the normal way....by using the 120 volt AC/DC charger..... but still should be able to use a small plug-in inverter to do the job.
My cheap little Remington and Norelco both last at least 15-20 shaves after charging.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 09-27-2015, 08:46 PM   #22
RV Vagabond Jerry
Jerry Dixon's Avatar
dcheatwood: I am really looking for a shaver without a battery - one that works just with a 12 volt plug.
Jerry Dixon is offline   Reply With Quote
12 volt
