Old 10-28-2015, 02:01 PM   #1
mjones12's Avatar
12-volt extension cord question
My portable air compressor has quit holding a charge, but it works great when I plug it into a 12-volt socket. However, I need an extension cord for it to reach my trailer tires. I read somewhere that the compressor is about 25 amps and that the available extension cords have a 5 amp fuse in them and won't work for that reason. Could I get one of these extension cords and change its fuse to something larger, or is that a dumb idea?
2013 Surveyor SP220
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 10-28-2015, 02:16 PM   #2
Dumb idea. You will get a large voltage drop from the wires and probably burn out your compressor. Running under voltage will cause it to draw more current and run hotter.
I'm not sure of a good solution. I would take it apart and put in a new battery or look into getting some LiPo batteries and make a set that gives you ~13 volts at 25 amps.
If your compressor can run over voltage (15v) a 10000 mah 4s LiPo rated for 30c should run it fine. You can also make a plug with some diodes to put it at about 13 volts.
barron.barnett is offline   Reply With Quote
Old 10-28-2015, 02:17 PM   #3
Why not use a regular 110 extension cord and modify it with the proper plugins for our use? put a regular 110 plug on the end of your compressor and an adapter for the other end of the extension crd.
2011 F350 Lariat Ultimate Dually 6.7 w/ B&W Companion
2014 Heritage Glen 356QBQ
2016 Explorer Platinum, 1998 Mustang
1SG(Ret) (1987) US Army Aviation
Days/Nights Camped 2016: 34
dogwood36322 is offline   Reply With Quote
Old 10-28-2015, 02:21 PM   #4
strat56's Avatar
Can you make the air hose longer instead of the power cable?
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 10-28-2015, 02:23 PM   #5
MilCop4523's Avatar
i run my portable compressor off the traielr battery - its 17 feet shorter than the truck battery.
2009 Heartland Sundance 31.5 XLT bunkhouse
2013 Ford F150 XTR ECOBOOST
"Of the troops - For the troops "
MilCop4523 is offline   Reply With Quote
Old 10-28-2015, 02:44 PM   #6
B and B's Avatar
I use a standard cheap extension on my 12 volt compressor. Mine is 40 years old. There is no way it draws 25 amps, maybe 10 amps. Yours was running on battery and most likely a 7.5 amp/hr battery, 25 amp draw would kill the battery in short order
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 10-28-2015, 04:54 PM   #7
A new 50ft air hose is the best way to go or put two together and have a 100ft
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
spock123 is online now   Reply With Quote
Old 10-28-2015, 05:54 PM   #8
HONDAMAN174's Avatar
Get a jump box and cover yourself on two matters. Not a jump box w/ compressor- just jump box with 12v outlet. Think I paid 65 for 900amp from Sears.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 10-28-2015, 06:05 PM   #9
Flybob's Avatar
X3 on longer hose. You lose very little performance with longer hose. If it must be portable, you can easily replace the battery. Just open it up and enter the battery number in amazon to find a replacement.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 10-28-2015, 06:06 PM   #10
Bluepill's Avatar
This ^ Simple and cheap.
2008 Itasca Meridian 37H
