Old 07-01-2015, 04:29 PM   #11
Herk7769's Avatar
OK, so I apologize for the video quality, I was in a hurry.
I think I will do it again with better lighting and the fridge off (I don't know if it was cooling or the converter was still charging my battery.) The "null state" was 2.7 amps and 116 volts.
First a little about the mods I did to my AC to get the start up Current DOWN to the observed amps 24.9 - Subtract 2.7 to what you see on start up and run so there is a comparison.
I installed a Hard Start capacitor in both the Fan Motor and the Compressor; then I added a delay relay so the compressor starts first followed by the fan about 5 seconds later. You can hear the compressor lug and the amps shoot up as the line voltage drops. Shortly later the blower starts peaking again at 17 amps as it comes online. Once both are on speed you can see the "running amps."
Before the mods I had typical startups around 29 amps that kicked my 3500 watt inverting generator off line.
I have a new CB and 10 gauge wire to upgrade my trailer socket to a full 30 amps to keep the voltage drop down when I run the AC.
HAM CALLSIGN - KC3FFW
Old 07-01-2015, 05:01 PM   #12
LandJ's Avatar
Sounds like the 15K is too much for a Honda 3000. My dealer told me Dometic recommends a 3.5KW generator.
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2016 - 47 nights
2017 - 47 nights
LandJ is offline   Reply With Quote
Old 07-01-2015, 05:32 PM   #13
LandJ's Avatar
Seems the dealer might not have good info... Dometic also recommends 3.5KW generator for the 13.5K unit as well. The running amperage is only .8A more for the 15K. Doesn't give a spec on startup current.
John and Linda
2016 - 47 nights
2017 - 47 nights
Old 07-01-2015, 05:52 PM   #14
Herk7769's Avatar
Look at the manufacturer's plate on the AC for a "fair" idea what the start up amperage will be. Look for something called LRA
That is Locked Rotor Amps or the amount of amps the compressor motor will pull at a dead stop. Once it starts turning the amps will drop to its operating amperage.
Column-by-Column: Locked Rotor Amps and KVA | Franklin AID
My LRA is 58 amps but the compressor will begin to turn almost immediately and my ammeter display is not instant so I get an average over the 1 second sample time.
RLA: Acronym for "rated load amps". The maximum current a compressor should draw under any operating conditions (running on speed). Often mistakenly called running load amps which leads people to believe, incorrectly, that the compressor should always pull these amps. You should never use the listed RLA to determine if the compressor is running properly or to condemn a compressor. The running amps of a compressor are determined by the evaporator temperature, condensing temperature and the line voltage.
FLA - Full Load Amps: Changed in 1976 to "RLA - Rated Load Amps".
That is why some folks have no trouble with their generator and others can't get it to go. Air temp, humidity, and line voltage play a big role in whether your Generator can turn the beast over.
Some generators are more sensitive to overload than others as well and may drop off line quicker than others.
Old 07-01-2015, 06:06 PM   #15
We had a 2013 Rockwood 8265ws with the 13.5 AC. We now have a 2014 Rockwood 8282ws with 15 AC. Glad we upgraded to the 15 AC. Cooled the whole unit down in a timely fashion. The 13.5 had to struggle and took a bit of time cooling the unit down.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 07-01-2015, 07:26 PM   #16
I have a 15K in my 2604. It works great in cooling both the bedroom and rear living area. I run it with two Honda eu2000s. My Progressive Industries monitoring system states that it pulls about 18 amps. 18ampsx120v = 2160 watts. Your 3000 should be fine, but you won't be able to run the microwave, water heater or coffee maker at the same time.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 07-01-2015, 07:51 PM   #17
I have a Dometic 13.5 and it runs no problem with my Yamaha ef2800i inverter generator (2800w surge, 2500w rated). I can even run my Microwave at the same time if the AC is already running.
I have used that generator for hours at a time in 115 degree heat here in Arizona and no issue with the AC other than it struggles to keep things cool. I have an extra teen in the house for the summer and I work at home. So I have been using the RV as my office during the week. The voltage drops enough from grid power in this heat to the point I don't want to trust my 15A circuit to run the AC (the AC itself is on a 15A circuit and when I run it connected to my home it is the only thing running on AC). So I use the generator for those hours and there has never been a problem
I can't see the 3000w honda being any different with a 15k AC.
Mike
Tinmania is offline   Reply With Quote
Old 07-01-2015, 09:01 PM   #18
LandJ's Avatar
Here's the answer I got back from the dealer....
Yes they do. There is only about 1amp difference between the two when running. The generator recommendation is because of startup. When the compressor starts on a 15k it momentarily draws about 66amps (13.5k about 63amps). If using a smaller generator it may not be able to handle this spike in demand and could damage the AC compressor.
There is only a slightly noticeable difference between the 13.5 and 15k. We normally stock 13.5k on all travel trailers under 35 ft. We option the 15k on anything over 35 feet and all 5th wheels and park models.
John and Linda
2016 - 47 nights
2017 - 47 nights
Old 07-02-2015, 01:34 PM   #19
LandJ's Avatar
I went with the 13.5K. I don't want to have problems with my generator. I can always upgrade later if it's not enough.
Thanks for the help.
John and Linda
2016 - 47 nights
2017 - 47 nights
Old 07-02-2015, 02:12 PM   #20
B and B's Avatar
I run a 4 kw (4.5 kw surge, 3900 running watts) Generator with my 15K no problems. Remember depending on generator model a Honda 3100 is only 2800 running watts with a 23.8 amps maximum current capacity.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
