Old 10-19-2014, 08:21 PM   #11
Thanks to everyone - will go the harpman's solution when we go to Florida this winter!
dpowli is offline   Reply With Quote
Old 10-20-2014, 11:45 AM   #12
Originally Posted by harpman View Post
No need to modify...I have 2 gray tanks..I actually love it...great for short stays..for full hook up all you need is an extra piece of hose..a female to female converter for your hose..replace galley cap with one that has a hose connection..connect hose to elbow that goes into sewer Attachment 65028Attachment 65029
With the galley tank valve left open, do you get any sewer smell inside the rv? Do you have problems with sewer water getting in the water hose when draining sewer line ?
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
Old 10-20-2014, 12:55 PM   #13
Ret E-9 Anchor-clanker
donanddona's Avatar
I do not have inside smells. Seams the P-trap work good in the galley. The garden hose connection is open all the time (same as the shower drain). I would close the galley cutout valve while dumping the black tanks (I have two of them) if your concerned. One last thought, I full time up to 2-3 months in the same CG. If you paper towel your dishes prior to washing them you may not have to disconnect the garden hose and clear it (back flush). I do now.
donanddona is offline   Reply With Quote
Old 10-20-2014, 04:29 PM   #14
I will make sure I use a 3/4 inch I.D. hose. We already do not dump any grease or large food particles down the sink. Thanks for the heads up though.
tank
