Old 05-15-2013, 06:54 PM   #11
dretired's Avatar
Originally Posted by D-mo View Post
always try everything new in the driveway ... could be a simple issue that needs little attention.
i would be pissed too ... but hey .. this is all i can say to prevent stuff like this happening ..
d-mo
Try it at the factory( quality inspection) and the dealer (PDI ) would be a much better idea...so...when you buy something... and you .. need it to work ..IT DOES !!
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 05-15-2013, 06:58 PM   #12
fonzie's Avatar
Since it is a gravity fed, most likely you have a kinked hose between inlet and tank. Maybe there is a check valve, but doubt it. A least you have an appointment tomorrow and not in a week or more.
Fonzie
Old 05-15-2013, 07:00 PM   #13
TURBS's Avatar
No check valve.
Heres a thought .......
The tank is able to move side to side while traveling ?
If the tank moves towards the fill side could it pinch the inlet hose against the frame ?
Old 05-15-2013, 07:23 PM   #14
The length of hose would be my guess, or a kinked air purge/overfill tube. Pretty easy fix. Pull off panel, check the feed and purge lines. If necessary, remove clamps from back of fill port, cut, re-install and zip tie to get to proper position if necessary.
mwebber78 is offline   Reply With Quote
Old 05-15-2013, 08:40 PM   #15
campfirefun's Avatar
Check valve is installed backwards I bet
campfirefun is offline   Reply With Quote
Old 05-16-2013, 05:52 AM   #16
Commercial Member
huntr70's Avatar
Good you don't bet often....there is no check valve in a gravity feed fresh water tank fill.
Most likely is a kinked fill hose, and the dealer should have caught that if they did a thorough PDI.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 05-16-2013, 06:54 AM   #17
Scratch's Avatar
Per PT, the problem lies with the vent tube. Quick, easy fix; RV Guy can explain...
Scratch sends...
'12 nights camped: 12
'13 nights camped: 24
'14 nights camped:
Scratch is offline   Reply With Quote
Old 05-19-2013, 10:54 AM   #18
dretired's Avatar
Update... Dealer claims the hose was too long with too many bends in it ..
Old 05-19-2013, 11:32 AM   #19
wyo700's Avatar
I had the same thing happen to me. The hose was to long and they had routed it over the wheel well and back up the the tank fill. So water had to try to go up hill from the start. I took it off ran it along the floor and back up to the fill neck. Fills just like its supposed to now.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 05-19-2013, 02:23 PM   #20
dretired's Avatar
I still cant get over the fact..it got past the factory and the dealer (so called ) prep... very LOUSY attention to detail ...Do they even care that a person buys a brand new 5th wheel... and cant camp with it their first time out ??
