Old 05-19-2013, 08:33 PM   #21
I can sense your frustration! I imagine the gravity fed inlet is not checked at the factory or the dealer. It is my impression that only the pressurized water inlet and the LP gas lines are checked for leaks via pressure readings.
Look on the bright side. Imagine a slow water leak that was not picked up and created a lot of grief down the road. Still, for the price you pay for these units, you certainly expect these problems not to happen. Hope you have smooth sailing after this resolution!
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 05-19-2013, 08:58 PM   #22
John McClain's Avatar
no check valve on the tank fill that i have ever seen , I did pull about half my Panel loose in the main storage compartment and the fresh water fill up went up hill because they routed it over the city fill line, it was a easy fix
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 05-19-2013, 09:04 PM   #23
OL Creeker's Avatar
What happened during the PDI? I'm just curious. We're going to take delivery of a CC and hope they check all systems before cutting the proverbial umbilical cord!
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 05-20-2013, 04:11 AM   #24
dretired's Avatar
Ask them to fill the tank with fresh water also...try the water pump at that time yourself...fire -up the water heater...i trusted my dealer and thought... (assumed) they had checked the fresh water -fill..didnt happen...
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 05-20-2013, 04:24 AM   #25
M109Rrider's Avatar
Had that problem with mine. Water in the vent line. Put an air hose against the little vent screen by the water fill and blew it out.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is online now   Reply With Quote
Old 05-20-2013, 06:25 AM   #26
I always take an old hose and cut about 10" piece off of the end. Now you only have one fitting on one end and none on the other end. It allows you to stick the hose down into the fill tube about 10", seems work for me
grayfox is online now   Reply With Quote
Old 05-20-2013, 07:00 AM   #27
Crusader's Avatar
Originally Posted by dretired View Post
Update... Dealer claims the hose was too long with too many bends in it ..
I had the same problem with my Crusader 270ret. I shorted and straightened the fill hose. It corrected the problem. Primetime needs to correct this problem on the line. It is a common problem with these units.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 05-20-2013, 07:24 AM   #28
CampingQueen
I agree, a good PDI should have caught this. The dealer where we bought both our campers does a very good check of all systems, including filling the fresh tank, running the pump, and checking that all water fixtures are in working order. I think a good PDI at the dealer may cost them a little more in people time, but sure does make a difference in happier customers. We have bought 2 different TT from the same dealer and have had NO problems at all, with either of them with factory or quality issues.
Glad you got it fixed, but hate that you had to go through the frustration. It certainly is not unreasonable to expect the major systems (water, LP, sewer, appliances) to work properly when you get a new TT.
2012 Flagstaff V-lite 30 WTBS
2011 Ford Expedition
4 kids and a hubby & never enough time to camp!
2011: 17 nights 2012: 26 nights 2013: 46 2014: 20 2015: 16
arlee453 is offline   Reply With Quote
Old 05-20-2013, 01:27 PM   #29
dretired's Avatar
Is Prime Time getting any of this ??? HELLO ??? ANYONE OUT THERE ???
Old 05-20-2013, 02:32 PM   #30
zs325RES's Avatar
I checked mine today and it looks OK. I can see where it could be an issue though. Pretty jumbled back there.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
