Old 05-15-2013, 04:16 PM   #1
dretired's Avatar
2 week old Crusader 325..CANT USE IT !!
We finally got a break to try out the new 5 ver..packed everything...got to the State Park...got our favorite site ...went to the water/sewer station ...tried to put water into the fresh water fill tube..its spiting back back out in a few seconds...got on the cell phone with service dept at dealer (tried various things they could think of)..it has to go back to the dealer in the morning ...I AM.. NOT... A HAPPY CAMPER !! PRIME TIME DO YOU SEE THIS ??? The dealer WILL ... get a earful also.... such a beautiful day today... and i am am sitting here writing this ...instead of camping
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 05-15-2013, 04:33 PM   #2
always try everything new in the driveway ... could be a simple issue that needs little attention.
i would be pissed too ... but hey .. this is all i can say to prevent stuff like this happening ..
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 05-15-2013, 04:57 PM   #3
fonzie's Avatar
dretired, is your fresh water fill up a gravity fed or a pressure type where you have to screw the garden hose to it?
Fonzie
Old 05-15-2013, 05:00 PM   #4
I had the same thought. I just looked at a Crusader brochure and it shows a gravity feed.
Old 05-15-2013, 06:33 PM   #5
dretired's Avatar
Gravity feed from what i can tell ...the city water connection has threads for pressure..How would i add extra water to the tank if i am staying at a park where i need to carry water jugs then pour it in ??... Very poor pdi and not a bit of quality inspection going on at Prime Time...
Old 05-15-2013, 06:36 PM   #6
zs325RES's Avatar
It's a gravity fed tank.
While at the factory they showed us the measures they go through to test the water lines and tanks, plus my dealer filled and tested it as well, so no issues here.
You might take off the basement wall panel (pretty easy) to access the area behind the universal docking center. The problem might be obvious and easily corrected.
I hope so.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 05-15-2013, 06:38 PM   #7
TURBS's Avatar
You have to fill the fw tank SLOWLY !
Look at the hole that the water goes into then look at the vent tube !
Takes at least 20 minutes to fill my 30+ gallon tank .
If you just crank on the hydrant I guaranty you it will spit back .
just slowly let it run in "TRUST ME"
You can add more water then air can escape so it burbs back .
I dont believe this to be a prime time issue.
TURBS
Old 05-15-2013, 06:43 PM   #8
dretired's Avatar
You can add more water then can escape so it burbs back .
TURBS
I tried the S_L_O_W fill it wont take water... or maybe 12- 20 oz... then it backs up..this is my 3rd rv.... so ...i know about filling the fresh water tank
Old 05-15-2013, 06:46 PM   #9
dretired's Avatar
Is there some kind of check valve in that Line ??
Old 05-15-2013, 06:50 PM   #10
dretired's Avatar
I hope so.
Tried that ..had dealer service dept on the cell phone..its going in at 9am ..service thinks.. it may be a bad check valve ??
