Old 08-07-2016, 09:15 PM   #11
asquared's Avatar
Originally Posted by Gary Honis View Post
Hi Vibe and Seadog,
I did not check the tourque of the lug nuts, because it was a new trailer. I'll be sure to check the lug nuts in the future on every trip. I only haul telescope gear in my toy hauler and it is a few hundred pounds at most.
The oval hole in the rim is most likely caused by the stud as the wheel was coming off the trailer.
Gary
Originally Posted by Oaklevel View Post
There probably is a sticker somewhere telling to check torque after so many miles. Our Puma has one but this is odd to me I have five trailers and have never had a wheel lug nut loose enough that would work its way off........ Also I too am very surprised that no studs were sheared off.
I am leaning also to the intentional theory............ hope that is not the case. That would be a bad trick to play on someone.
Regardless of how it happened glad no one was hurt........
Wow glad everyone is safe. I forget where I saw it (manual or sticker) but I remember reading the need to tighten the lugs every 150-200 miles or so when new or when tires changed as they may work loose.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is online now   Reply With Quote
Old 08-07-2016, 09:39 PM   #12
Witch Doctor's Avatar
I can see 1 or 2 working loose but not all of them at the same time, Glad your okay. I'll bet 100.00 dollars to a donut that the transport people don't check them. I didn't even see a broken one, unless I missed it. It takes a lot of miles to seat those alum wheels they put on, I thought I read somewhere it was every 150 miles or so, can't remember now. I think the torque on mine 110 lbs. or at least that is where there set to... There are some pretty high torq. on that chart from e trailer, Once again glad you are all right they can always fix the trailer...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-07-2016, 09:40 PM   #13
Airdale's Avatar
I bought a new 2016 Forest River Palomino Puma 21-TUC toy hauler in March. It had to go back to the factory for many problems and I picked it up on April 20 at my local RV dealer. This past Wednesday two wheels on the passenger side came off and I was able to steer it to the side of the road. The trailer has a lot of damage. It was towed using the Coach-Net service to the nearest RV dealer. That dealer is located 135 miles from my home. Good thing nobody was hurt. You can see the damage to my trailer here:
August 3, 2016 Forest River PUMA Palomino Toy Hauler Accident Photos
Gary
"Make sure all of the lug nuts are secure. Use a torque wrench. Do not guess."
It's in here, or look in yours. It's under tire safety.
Forest River Manuals
USN - RET
DOD - RET
SSA - RET
Airdale is offline   Reply With Quote
Old 08-08-2016, 11:22 AM   #14
When I pulled over to the side of the road, the lug nuts were all about half-way turned off of the wheel studs on both hubs. There was no damage to the threads of the wheel studs. My RV dealer said that happens when the lug nuts become loose. The wheel begins to wobble and the rim breaks up.
Gary
Gary Honis is offline   Reply With Quote
Old 08-08-2016, 11:23 AM   #15
My sticker says to recheck lug nut torque every 50 miles for the first 200 miles after having a wheel off.
2003 GMC 2500 HD 8.1 & ALLISION TRANSMISSION
2000 SIERRA 30 ft FKSS
hondo is offline   Reply With Quote
Old 08-08-2016, 11:49 AM   #16
DaveSchwartz's Avatar
Torque checked to 100 ft-lb on aluminum wheels before every trip. Previous TT manufacturer sent a special letter and DVD (probably their lawyers did ) saying 150 ft-lb on steel wheels.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 08-08-2016, 12:56 PM   #17
raytwntrvlr's Avatar
I have a torque wrench and deep socket handy always when towing... check constantly.. only ever found a couple somewhat under torqued... by no means loose.
Seems suspicious that all came off on both wheels on the same side.
Glad no one was injured.
2015 Flagstaff Super V 26VFKSS Emerald
2013 RAM 2500 CC 4X4 6.7 CTD
Sold... 2013 Shadow Cruiser 260BH
raytwntrvlr is offline   Reply With Quote
Old 08-08-2016, 01:07 PM   #18
CaptnJohn's Avatar
WoW! Glad no one was hurt! Looks like a lot of damage. The buckled floor gives concern of the frame and the possibility of it being a total loss.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 08-08-2016, 01:48 PM   #19
Senior New Member
2 wheels came off ...
Gary,
Just another opinion...provided you don't have any known chicken ***t enemies, someone may have wanted your new wheels and tires, then opted out for some reason and left the scene in a hurry.
Although, as you'll notice from many posts over time, there are many dealers that do not do a good job on repairs or set-ups. Adding to check lug nut torque to your checklist, just like tire pressures, would be a good idea.
Glad you were able to exit the roadway without injury !
ausstar is offline   Reply With Quote
Old 08-08-2016, 02:28 PM   #20
I too am going to lean towards the scenario that somewhere between the factory and/or at the dealer, someone tried to steal your wheels and tires and were somehow interrupted.
It is unfortunate you didn't notice anything suspect before leaving the dealer but I am also glad no one was hurt.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
puma, towing, toy hauler, wheel
