Old 06-25-2018, 11:51 AM   #1
20 amp shore power hook up
2015 dynamic DX3 trying to hook up 110 thru a 20 amp circuit in my storage facility to run my refrigerator . Keeps tripping the breaker. Used to do this with my Isada. Any ideas. Everything else works normal.
3 amigos is offline   Reply With Quote
Old 06-25-2018, 12:03 PM   #2
Is the outlet you are hooking into a GFCI?
Many times the GFCI in the rig and the one in the outlet don't play nice with each other.
Eliminate the one by finding a non-GFCI outlet to plug into.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 06-25-2018, 12:07 PM   #3
D W
D W's Avatar
I would venture to guess that "code" requires receptacles in your storage facility to be GFCI protected much the same as a garage. Like 5picker said, two GFCI's in tandem often don't play well together.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 06-25-2018, 12:40 PM   #4
It is a GFI. I'll try one without.
Old 06-25-2018, 01:49 PM   #5
Check your breaker that keeps tripping. If it is one of the latest breakers that has an arc detector built into, you may be able to change out the breaker and everything will work fine, even with your GFI receptical.
The arc detecting breakers in my house do not like my coffee pot. Every time the heater cycles the breaker trips. Probably a cheap, arc-producing switch in the coffee pot.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 06-25-2018, 02:48 PM   #6
SailorSam20500's Avatar
One other thought, your new rig may be drawing more current to charge batteries, etc. If the GFCI isn't the issue, I'd look to see what other loads are active.
Al
Save the Earth. Itís the only planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 06-25-2018, 03:46 PM   #7
bend302's Avatar
X2.
I'm with Sam, there may be other things drawing current that you are unaware of. Leave it plugged in with nothing manually turned on for a few hours or overnight then see if refer works. One sneaky item is water heater. You forget it's on until you need it.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 06-25-2018, 09:29 PM   #8
Bluepill's Avatar
You may be able to get easy access to the reefer power plug by just removing the plastic vent panel on the outside of the RV. You can then unplug it from the RV and run an extension cord direct to the storage facility outlet.
2018 Coachmen Freedom Express 192RBS
Old 06-25-2018, 09:33 PM   #9
Flybob's Avatar
If you turned on the WH in electric mode ( or it was still on) without being full of water, you could have burned out the element, It can cause a GFCI in the supply line to trip. It only takes a second or two to burn out.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
power
