07-23-2019, 09:19 PM
24 volt battery?
Hi, I recently purchased an apex nano 208bhs- a 12 volt system.
I don’t intend to keep the battery the dealer gave us as we want to switch to lithium. However, we noticed that it is a 24 volt marine battery.
Will using this 24 volt battery on our 12 volt system (until our lithium is purchased) damage it? Is it the same as using 2 - 12 volt batteries in parallel?
07-23-2019, 09:24 PM
Reminds me of back in the day when a friend tried a 12V battery in a 6V car. Blew all of the light bulbs fast.......................
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Are you sure it isn't a group 24 battery? (refers to size)
Can you post a photo of the battery?
Have you checked the voltage at the battery posts with a multimeter?
07-23-2019, 09:25 PM
Can you post a photo?
That would make more sense ...................
1966 Mustang GT
1986 Mustang SVO
07-23-2019, 09:32 PM
Sumpin I ain't seen before is a 24v battery. Sounds more like a group 24 to me. Better put a meter to it and se for sure what you have.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
07-23-2019, 09:34 PM
Always Learning
If it IS a 24v battery (which I agree with the above that it likely isn't), you need a 24v to 12v converter to feed the RV system. And likely need a different charger in order to charge it.
07-23-2019, 10:32 PM
Oh that makes so much more sense. Thank you! I checked and the battery only has one label. 24 V. CCA 550. 140 RC. And is an Interstate brand.
Too dark here for pics. But the dealer showed us the lights and the slide using this battery and it didn’t blow any bulbs so I’m guessing it is what you guys are saying.
07-23-2019, 10:46 PM
I'm betting that if you read the lettering in the battery, it'll say GROUP 24, not 24 volt.
Not aware of Interstate making a 24v battery, but I could be wrong.
07-24-2019, 08:15 AM
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
07-24-2019, 08:29 AM
It is unlikely it is a 24V battery. You should have a small volt meter for testing anyway, so now is a good time to get one. If you have a Harbor Freight near you they usually have one for Free or almost free.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-24-2019, 08:39 AM
If your sticker is comparable to this one (with the same specs you posted) it is a 12v battery.
As someone who possibly questions whether they have a 24v battery in a R/V, I suggest you go to the Library section of the forum and read up on the many different systems in an R/V. It will help you better understand the various components in your R/V
07-24-2019, 09:03 AM
Broken Toe
24 volt battery would have 12 cells, not 6. If its not sealed, remove the fill caps and count the holes where you add water.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
