Old 10-20-2017, 10:19 PM   #1
26 rr CO alarm going off for no known reason
I do not have propane on, I'm not living in it. Just plugged in to land power and it started going off. Any suggestions how to fix. ??
ruddie66 is online now   Reply With Quote
Old 10-20-2017, 10:43 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
I have found them to have a limited shelf life. How old is yours?
donanddona is offline   Reply With Quote
Old 10-20-2017, 10:46 PM   #3
It's a 2016, just plugged in to get batteries recharged. Than it went off.
Old 10-20-2017, 10:49 PM   #4
Short of unplugging and pulling battery off, is there another way to turn off ??
Old 10-20-2017, 10:55 PM   #5
donanddona's Avatar
I took the two screws out, pulled it out of the wall and cut the wire. After finding the reason it was going off I re-spliced the wires. Not the right way but it worked. OBTW the DW left a bottle of swifter cleaner next to the trash that was next to the sensor. Vapors, wow.
Old 10-20-2017, 11:00 PM   #6
Ok thanks, I do know about vapors and other products that can set off. So I should cut wires ? Is there a fuse that can be pulled ??
Old 10-20-2017, 11:12 PM   #7
So I pulled the alarm from the bracket, unscrewed the mounting plate, pulled wires out and found 2 wire nuts to alarm, undid one. No more alarm noise. Will now have to get a new one. Thanks for your help.
Old 10-20-2017, 11:30 PM   #8
Moderators' Assistant
bikendan's Avatar
Usually goes off because the battery is low, as it's probably hard-wired.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-21-2017, 12:58 PM   #9
RudysWorld's Avatar
On my Georgetown a drawer is behind the alarm and there is a fuse back there. You can pull the fuse. FYI, pulling the fuse will shut off propane. My alarm was do to fumes from battery which is directly below alarm. There was a bad cell and would overcharge. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 10-21-2017, 01:26 PM   #10
2011_ChaparralLite_270RKS
Safe T Alert senser
Mine chirped every 30 seconds with a solid green light when I let the battery get a 'little' low. According to the leaflet that came with it, that is by design. Once I plugged in to shore power and the battery charged up 'enough' the chirping stopped completely by itself.
Katja is online now   Reply With Quote
