Old 07-12-2016, 08:48 PM   #1
Cuzdog's Avatar
26RR Shower Leak
Has been talk in the past about the shower leaking into the floor on the 26 RR. I haven't seen any discussion in some time, if this is still an issue or recommended fixes. I resealed mine and still leaking, can't pin point the actual spot of the leak.
Any suggestions?
2015 26RR
2013 F150 5.0
2011 Harley Touring
Cuzdog is offline   Reply With Quote
Old 07-27-2016, 12:06 PM   #2
rmac04401's Avatar
Some water may come from just the piece under the shower door as you open it. I usually have some just in the little channel of the base of shower. I think it comes from when I open shower door. This winter I'm going to take all the glass and door off and redo. I did one side when I adjusted the surround. I think you pretty much need to remove all shower glass and frame and remove caulk and make sure you have bead under the frame before reattaching. That fixed the side I actually did when I first got camper. Hind site should have done whole thing that way.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2002 F150 5.4L extended cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
leak, show, shower
