Old 05-13-2018, 07:03 PM   #1
KWhite2018's Avatar
2nd shower doesn’t drain
Hi,
We went on our shakedown trip this weekend and we learned that the shower drain is clogged 100%. We let the water sit for a day before scooping it out for the drive home.
Has anyone experienced this?
We are home now so we’re going to inspect it more.
KWhite2018 is offline   Reply With Quote
Old 05-13-2018, 08:27 PM   #2
mjones12's Avatar
Originally Posted by KWhite2018 View Post
Hi,
Does that shower have its own gray tank, which could possibly be full?
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 05-13-2018, 08:31 PM   #3
KWhite2018's Avatar
None, of the tanks were used except to brush teeth. We can’t do anything because the pipes are glued together so we just put it on the list for the dealer.
They wanted a 90 day check up with a list of repairs.
Old 05-14-2018, 04:01 AM   #4
nomad297's Avatar
You may have a waterless trap that is installed backwards.
Bruce
Old 05-14-2018, 06:11 AM   #5
realebill's Avatar
Could you follow up with the solution to the drain issue in case anyone else has this problem after you have it resolved.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 05-14-2018, 09:32 AM   #6
KWhite2018's Avatar
I definitely will!
Old 05-14-2018, 09:58 AM   #7
Bruce
I had a issue like this is our unit and it turned out the rubber boot was sucked up backwards plus the sawdust in it didn't help either, cleaned it out and all worked well but still had the factory give me a new drain valve. Good luck and yes please keep us posted.
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2016 Smart for Two on deck
dblr is offline   Reply With Quote
Old 05-14-2018, 03:58 PM   #8
That is called a waterless trap and all you need to do is run a peice of wood or small plastic pipe down the drain a bit to see if that will open up the drain. I’ve not seen many of these on shower drains to be honest. Mostly on outdoor kitchen sinks where room in at a min for clearance
Kygoldwinger07 is offline   Reply With Quote
Old 05-14-2018, 04:07 PM   #9
KWhite2018's Avatar
I’ll go out and try it right now.
We did use a coat hanger and we hit something. So I’ll try something stronger.
Old 05-14-2018, 04:19 PM   #10
KWhite2018's Avatar
So, I used a screw driver and it stops about 1” down and whatever I’m hitting is solid as a rock! I pushed and jammed it down but it didn’t budge.
We take it in on Thursday so I’ll let you guys know what they say.
Old 05-14-2018, 04:24 PM   #11
nomad297's Avatar
If it’s only going down about an inch, you don’t have a trap there. You are probably hitting the bottom of a 1-1/2” ABS 90 which leads to a waterless trap. That is, unless there is a trap and something hard has gone down and stuck there. Have you shop vacuumed all of the water out of the shower? If so, what do you see down the drain?
Bruce
Old 05-14-2018, 04:28 PM   #12
KWhite2018's Avatar
Bruce
I haven’t sucked all the water out of the drain. I’ll run out now and try it and take a pic.
Old 05-14-2018, 04:33 PM   #13
KWhite2018's Avatar
Bruce
Can I plug the shop vac into an inside outlet if I’m on shore power? Will I blow anything?
Old 05-14-2018, 04:35 PM   #14
nomad297's Avatar
Of course.
Bruce
Old 05-14-2018, 04:49 PM   #15
Cheese456
Clogged Shower Drain: Fixed
Same problem: simple solution. Our new Dynamax Isata came and, brand new, the shower would not drain. Based on comments, I stuck a small screwdriver about 2" down through the drain and it popped open the waterless drain. Took 10 seconds and works perfectly now.
Chris
2018 Dynamax Isata 3
Cheese456 is offline   Reply With Quote
Old 05-14-2018, 04:50 PM   #16
KWhite2018's Avatar
Of course.
Bruce
No luck. I couldn’t get all the water out.
We have a few items on our list so the dealer can check it out.
Thanks for your help!
Old 05-14-2018, 05:06 PM   #17
Here's a video of what you probably have:
You'll want to poke at it with something flexible, like a snake, not a screwdriver.
2011 Traverse LT, 3.6L, FWD
Old 05-14-2018, 05:27 PM   #18
Cheese456
Thanks for the informative video on what a waterless trap is. I must have something very different? I can see a metal 'flap' 2" below the shower drain screen. I put water in the drain, it would not drain. Then I poked a screwdriver right on the metal flap, nudged it, and it opened, and all water drained. Turned the shower on and it drains perfectly. So others - please don't use my screwdriver solution unless you know what you are doing - it might not work for you.
Chris
Old 05-14-2018, 05:30 PM   #19
KWhite2018's Avatar
I believe I have a metal trap too!
I liked the video though!
Old 05-14-2018, 05:34 PM   #20
OK. You might have one of these:
Waterless odour trapÂ*- KESSEL - Leading in drainage
drain, show, shower
