Old 09-07-2016, 09:37 PM   #1
fastalkintn's Avatar
30 or 50 amp?
We recently purchased a new 27rkss and absolutely love it! During our PDI the tech said that even though it is a 30 amp unit we should always use an adapter and plug into 50 amp service if available. After the PDI the service manager recommend the same thing. I haven't been able to find this information anywhere else, what are your thoughts? Any pros and cons to doing this?
2017 Nissan Titan XD CC SV
2017 Salem 27RKSS
fastalkintn is offline   Reply With Quote
Old 09-07-2016, 09:50 PM   #2
Iwannacamp's Avatar
Yes. You can use an adapter to connect to 50amp service if needed. No issues.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Old 09-07-2016, 09:52 PM   #3
I understand no issues if needed, I guess my question is is there any benefit to doing it if I don't have to?
2017 Salem 27RKSS
Old 09-07-2016, 09:52 PM   #4
I've done it with an adapter because it was only 50 amp. I have never heard of always doing it. Maybe I'm missing something?
2016 Coachmen Freedom Express Liberty Edition 292BHDS
FRRVR is offline   Reply With Quote
Old 09-07-2016, 10:09 PM   #5
Wobbles's Avatar
IMHO, I think what he was saying was... "Possible trouble with the campground electrical post"
The initial logic is that the 30A plug is the most common and gets worn out more that the 50A. Worn electrical connections can cause problems for your unit.
Invest in electrical protection, not just a surge guard.
I have a 30A TT and a commonly called "dogbone connector". It is a short thick extension cord that plugs into the female 50A plug on the the post with a 30A female connector for my TT cord. I use it when stuck at a 50A only site or when there is trouble with the electrical service. Troubles can happen at a campground that is packed during the hot summer and people are taxing the electrical grid running ACs.
If you have troubles with the 50A, move... Remember a surge guard will not warn you of all electrical troubles and may not not protect you from them.
I know others here can say this better and in more detail than I.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2015 Grey Wolf 26BH
Wobbles is offline   Reply With Quote
Old 09-08-2016, 08:32 AM   #6
Actually, If your RV is set up for 30A, you will get slightly more power if you use 30A service compared with 50A plus adapter.
30A service comes in on 1 phase meaning a single wire carries the entire load.
50A service uses 2 phases meaning you get (2) 25A wires.
When you use a 30A to 50A adapter, you only connect to one of the phases meaning all you will get is 25A.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 09-08-2016, 08:39 AM   #7
wmtire's Avatar
Tim, actually a 50 amp service is two legs of 120 volt, each at 50 amps (100 amps total).
You are correct that the adapter only connects to one leg, but this leg is 50 amps (not 25).
The 50 amp split phase 120/240 volt service is actually one of the most common misunderstood things, and here are some better links to help explain it.
Electrical Tutorial - Chapter 3 - 30 Amp versus 50 Amp
RV Electric
and a schematic:
2011 Flagstaff 831 RLBSS
I've invented a new word. "Plagiarism"
Old 09-08-2016, 08:43 AM   #8
ilmor's Avatar
Good info, I never knew this. I've only carried my adapter around in case 30A wasn't available. Now I'll actually use the darn thing!
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 09-08-2016, 08:58 AM   #9
fonzie's Avatar
also a 50 amp site usually cost more per day than a 30 amp site.....FYI
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 09-08-2016, 09:04 AM   #10
Head Rambler
I use the 50 to 30 amp pigtail whenever I can. I only use the 30 amp plug if 50 amp isn't available.
I'm not looking for more power, but the 50 amp pedestal receptacle is usually less used and abused than the 30 amp one is.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
50 amp
