Old 09-14-2011, 11:00 AM   #1
drvol's Avatar
30amp to 50amp
Wanting to camp at a campground we frequent from time to time but the only sites left are 50amp. Just want to make sure and hear from those that know...can I safely hook to a 50amp site with the proper 30amp to 50amp adapter without burning anything up on my Shamrock 233S. Does the adapter itself reduce the voltage to avoid damage to appliances/AC/slide and awning motors, etc.???
And what brand adapter do you recommend if one is more reliable than the others???
2011 Flagstaff Shamrock 233S
2008 GMC Sierra 2500 Duramax
Great Smoky Mountains
TN
drvol is offline   Reply With Quote
Old 09-14-2011, 11:11 AM   #2
Oakman's Avatar
I have a dogbone adapter for hooking up to 50 amp service. In 8 years of camping with a fifth wheel I've only had to use it once. Most campgrounds that have 50 amp service will also have a 30 amp outlet. Many times they only list the 50 amp because they charge more for the site.
I think you're confusing amps with volts. It will still be 120v service so it won't damage any appliances. It you use too many amps it will trip your 30 amp circuit breaker. Just use your trailer like you normally do and you should be fine.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 09-14-2011, 11:16 AM   #3
Phat Phrog Phlunky
essness's Avatar
The 50 amp service only makes the extra 20 amps available should you need it. It will not damage anything.
I have a dog bone adapter as well and have used it a couple times already.
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
essness is offline   Reply With Quote
Old 09-14-2011, 11:22 AM   #4
drvol's Avatar
Gotcha...yes confused is right, increased amps to a "greenhorn" means increased voltage too...thought it made a difference...but thanx for the clarification.
TN
Old 09-14-2011, 12:48 PM   #5
KyDan's Avatar
Most campgrounds will loan you an adapter if they have to put you on
a 50 amp site. I said "most".
