Old 05-27-2018, 07:45 AM   #1
3rd use broke hot water heater
So I have a 2018 Forest River FSX 197 BH. I used it for the third time this memorial weekend and the board on the hot water heat is shot. It's a Suburban SW6D. When I called my dealer they said that happens within the first year to most campers. What's up? They have been making campers for what's 50 years? Dont have it down yet? Also with temps in the 80's I couldn't keep the camper remotely cool with Windows and screen door open. Granted it wasn't very shady but it was an oven. Lucky I had electric and could run a.c., just worried about boondocking trips in the future.
wabakimi07 is offline   Reply With Quote
Old 05-27-2018, 07:52 AM   #2
You need a New Dealer! Now if the Dealer said "This happens every Spring when people try to "Unwinterize" i would agree but Not the 1st year Crap! Youroo!!
Old 05-27-2018, 07:56 AM   #3
cavie's Avatar
How did you verify this.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-27-2018, 07:59 AM   #4
nomad297's Avatar
X2????
Bruce
nomad297 is online now   Reply With Quote
Old 05-27-2018, 08:00 AM   #5
Iwannacamp's Avatar
These water heaters had much trouble with the circuit boards...if that’s what is wrong. My memory tells me the issue was “fixed” some time in 2017. Guess that would depend on when your WH was made. Good luck with your journey.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Old 05-27-2018, 08:18 AM   #6
The board was not tested because I was camping and the dealer is a long way from me. I went to a camping world near where i was and based on what the heater was doing they said it was the board. I then called my dealer and they said the same thing. It lights only once in awhile and when it does it goes out immediately. It may not be the board but through process of elimination I believe that is the culprit. The tips of the igniter are clean and have correct gap and it's getting propane, the tube is clean. The dealer is allowing me to install the new one and reimburse me for it if it was bad. Around $80 on Amazon. Hopefully they keep their word.
Old 05-27-2018, 08:26 AM   #7
Anyway new to this forum. Hopefully I pick up some useful information from people more experience than I. Thank you
Old 05-27-2018, 08:38 AM   #8
wmtire's Avatar
Yes, Suburban has had a batch of bad ignition control boards/modules..so that very well could be the problem. We have a lot of threads on these forums about this.
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 05-27-2018, 08:40 AM   #9
nomad297's Avatar
Welcome! You came to the right place.
Bruce
Old 05-27-2018, 08:40 AM   #10
it may well be the board, but i do not know how to test it and verify that this is the case. the sw6d does not have an electric heating element so that option is out. before i just blindly replaced the board i would attempt all recommended troubleshooting procedures.
if you replace the board, many posts have recommended replacing with a board made by DINO electronics. i may not have that name correct. this would work for you as the dealer is offering a cash rebate instead of a replacement board.n the DINO support people may have some information on testing the board.
i have to question the statement made that these boards go out within the first year. sure some people experience problems. but how many water heaters do you think are shipped out each year? how many actually have a problem? we are on our 3rd plus year and have never experienced a problem. and how good a job is the dealer doing selling units knowing they will fail within a year? i don't blame the dealer for the problem, but his response seems a bit off.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
heater, hot water, water, water heater
