Old 03-26-2013, 08:48 AM   #11
camper1999's Avatar
Originally Posted by herk7769 View Post
My only additional input is this:
If the camper is going to use a fair amount of power (up to the 15 amp limit of the outlet), the adapter should be as close to the outlet as possible, Trying to suck water through a straw gets harder to do, the longer the straw.
Same with electrons.
Trying to draw more than 10 amps through a long 15 amp extension cord could drop the voltage to dangerous levels. Using an adapter right at the outlet (then a larger sized wire run to the camper) will allow the same amount of amps to flow without the accompanying large voltage drop.
Voltage Drop Calculator
X2 do not use less then a 12 gauge cord and use the shortest one possible, use it to run the refrigerator and charge the batteries, do not run the a/c, fireplace, or anything else that will draw a lot of power
2011 GMC 2500HD Diesel
Old 03-26-2013, 02:41 PM   #12
dretired's Avatar
Thank you for all the input everyone
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
