Originally Posted by Labzy
Speaking of adapters.....is it possible to get a 30->15 amp reducer that attaches directly onto the trailer like the female end (with screw on ring) that came with the trailer?
that would be a NO - you would have to put the cord into the camper and change it at the other end that plugs into the pole.
To answer the OP's Question - Bought my camper in March 2011
I have used my 50 to 30 adapter once - saved me because the 30 amp breaker kept popping on the pole so I hooked into the 50 amp side and had no issue's with the breaker popping.
I had never had a problem like that so am thinking the 30 amp breaker on the pole was weak.
Well worth a little extra to buy the adapter's now so if you run into an issue you can remedy it faster then trying to go to the store and finding it or not finding it when you really needed it
