Old 08-20-2016, 01:07 PM   #21
Originally Posted by Kenny kustom View Post
Magnum msh3012m
It's a 3k watt inverter than can use battery power to support the shore power. I split most of the rig ac circuits into the sub panel.
I tell the inverter to use 14 amps from the shore power. Any more draw, and the inverter will pull from the batteries.
I also run both fridges on electric while on the road.
Attachment 117740
I did some testing the other day.
Ran the front ac right off the batteries. Attachment 117741
After an hour, the batteries were still at 85% SOC.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Bring Back The Search!
Wow! I must be missing something! Just how much battery capacity do you have? 85% after an hour is incredible even if the AC cycled on and off for the whole hour!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 09-26-2016, 10:09 AM   #22
Taranwanderer's Avatar
Going to shift gears here: what happens if you plug a 30a camper into a 50a outlet using an adapter? It seems like overkill, your camper can only use 30a and will trip the main onboard breaker if anything tries to draw more than that. But can it damage your camper's wiring?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 09-26-2016, 10:18 AM   #23
Evereddie's Avatar
NO. Would cause no damage. This is not a problem. The camper will draw only what it needs. You are still protected as before with the 30 amp breaker in your camper.
There are 10 types of people in the world.
Those that know binary, and those that don't.
Evereddie is offline   Reply With Quote
Old 09-26-2016, 11:15 AM   #24
Plugging a 30 amp camper into a 50 amp pedestal is no different than plugging your 3/4 amp phone charger into a 15 amp receptacle (which is often on a 20 amp circuit)... absolutely nothing.
Your camper only draws what it needs. The 50 amps aren't "forced" into your camper. In addition, you still have a 30 amp breaker in the camper.
325BH is offline   Reply With Quote
50 amp
