01-27-2017, 09:30 PM
5th Wheel Rear Cargo Carrier Help
We got one of the Cricket Mini Carts at the Tampa RV show and thinking of adding a rear cargo carrier to our CC 36CKTS. At present I added a front carrier on the Ford F350 front hitch that of course extends forward that has a weight rating of 500 pounds. Total weight of cart and carrier is around 375 pounds. Would like some input as to what problems I am looking at by adding carrier to rear of 5th wheel. I know it will have to be attached to frame and have a frame person who can do that BUT what I am worried about is how it will affect the pin weight ratio as will as how it pulls and handles. If anyone has some experiences and willing to share I could use the help.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
01-30-2017, 12:12 PM
Bump...No one have one
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
01-30-2017, 12:26 PM
Adding weight behind the rear axle like that could adversely effect handling by unloading the hitch too much.
01-30-2017, 12:39 PM
I would hazard a guess that you won't get many answers because I doubt anyone has done this. I certainly would never consider it. Too much weight and makes trailering too lengthy to boot......not to mention strain on the frame.
FROG AR-0019-242
01-30-2017, 01:04 PM
I have seen several going down road where they have a motorcycle or other things on them, have not had the chance to talk to anyone who has done it. That is my worry about pin weight or if I could add water to fresh tank to off set that. Just fielding some answers and getting info. I may end up leaving it on front of truck like a big snow plow lol.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
01-30-2017, 01:12 PM
Maybe you should consider a swivel wheel trailer:
There are a number of manufacturers. Here's one:
Cruiserlift.com
2011 Traverse LT, 3.6L, FWD
01-30-2017, 01:15 PM
I would also worry about cracks in the corners of the wall cutouts for the slides and such. Axle placement is based on overall length and floorplan so frame flex is kept at a minimum to prevent stress in the walls.
A longer moment arm (from axles to rearmost load) than designed, could flex the frame, perhaps more than the "as designed" wall structure and/or frame can handle.
That swivel wheel looks like it will solve the long load issue.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
01-30-2017, 01:47 PM
There was a Big 5w parked along the Southwest corner of Locust & Ring Road during the entire "Frog Rally"! They had a Swivel Trailer attached to the 5W plus the Big TV plus the Golf cart,A Person could NOT Miss seeing it while walking the Rally! I think they were from Iowa,and were selling them? Youroo!!
01-30-2017, 02:28 PM
Roger,
I'm in the process of doing this very thing.
Difference being, my 5th wheel was built from the factory with an extended rear frame/bumper for a bike/cargo rack. I opted not to get the factory rack as I have a few ideas of my own I wan to incorporate into the design.
When I get the fold-up bike rack part done, it will match the cargo rack platform to give me a larger cargo area when not hauling bikes. (we may not take bikes when we go more full time)
I already have the cargo portion of the rack built and installed and have hauled probably upwards of 200 lbs. on it with no ill effect to the pin weight or handling.
Here are some photos.... The last photo is of the factory rack. (not my rig either) You'll see it doesn't incorporate any full time cargo space. My fold-up part (which will be removable) won't be quite that big but will give me a nice addition to the cargo platform when finished. I just need to get in gear and finish it.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
01-30-2017, 02:37 PM
The 36CKTS does not have a bumper.
FROG AR-0019-242
01-30-2017, 02:49 PM
Which is why I said... "Difference being, my 5th wheel was built from the factory with an extended rear frame/bumper."
No reason he couldn't do something similar off the frame.
01-30-2017, 02:52 PM
I called a couple of the swivel trailer makers and have some info coming and down loaded. I think that is the way I will go, as Lou stated I am worried about frame twist and movement. For right now this is what I am using, just have to learn how to drive different. It is rated at 600 pounds load cap., the carrier and cart total at 398 pounds so I should be ok.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
01-30-2017, 02:54 PM
Do you have any pictures of how they extended your frame.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
01-30-2017, 03:12 PM
No I don't.
The frame is a 6" heavy, real I-beam. (not two bent C-channels back to back like some)
They welded 2" x 4" rectangular tube onto the I-Beam to make the extensions with a 2" x 4" crossmember at the attaching point..
01-30-2017, 04:39 PM
[ATTACH]128941[/ATTACH
Loaded for transport.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
01-31-2017, 11:14 AM
Looks like you will Not need a "Bug Gard" but maybe a "Snow Plow Light Kit" and additional 'Air Intakes" for Cooling Turbo/Engine/Oil/and Trans! Youroo!!
01-31-2017, 12:47 PM
My 2008 GMC Sierra Crewcab with Duramax Diesel is very close to my front axle GAWR. With our front hitch installed and the bike rack and bikes mounted; it is right at the maximum weight on the front.
Gas engines most likely won't have this problem though.
01-31-2017, 06:06 PM
I am safe checked and my front end is rated to handle around 650 pound snow plow so I don't think the 348 pounds of cart and rack are going to be problem.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
01-31-2017, 06:33 PM
Having the F350 makes all the difference.
01-31-2017, 06:47 PM
His F-350 is a Power Stroke with Plow pack! Youroo!!
