Old 06-19-2016, 06:42 PM   #11
Retired
RubyDually's Avatar
Originally Posted by Davidg View Post
Positives: more storage, pulls waay easier with no sway, (even when that 18 wheeler passes you), easier to maneuver/backup. solid hitch lockup (no swaybars, or leveling bars to contend with). Usually built stronger with stiff frames. Usually storage tanks are larger. Tend to be more stable when set up. Provides justification to buy nice truck.
Negatives: Requires a nice truck, heavier, almost always a 3/4 ton truck at a minimum with diesel preferred. Hitch takes up much of the truck bed. Carrying bicycles can be a challenge, depending on use of rear of rv. More expensive, usually 25% - 50% more expensive for same living space.
Some of these are not absolutes and are just my own opinion/perception from having owned both types.
Davidg nailed it... other than requiring a nice truck isn't a negative...
We've had both and with considering the negatives it's a fifth wheel hands down for us.
Easier to hookup, more stable (especially with the dually), lots of headroom, more storage and the list grows.
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 06-19-2016, 06:57 PM   #12
dcheatwood's Avatar
5ers have more storage unless you compare it to a TH TT. There are a lot of large, really nice floorplans now in travel trailers but they get loonngg behind the truck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-19-2016, 07:06 PM   #13
Hutch333id's Avatar
We've had both and definitely prefer a 5er. We also went with a 1 ton diesel dually so we have very little concern about towing it. Admittedly, we don't full time in our rig but certainly could if the opportunity presented itself. Acres of space inside for our needs. There's countless floor plans from a variety of manufactures but my DW fell in love with the CC38 FL. We have since looked at others but apart from the newer, six slide 38FL, we wouldn't change this for anything else.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 06-19-2016, 07:25 PM   #14
Cyber Phrenologist
Radio's Avatar
The question not asked here is this: Are you going to park it in a site and live in it? Or are you going to go on a 10 year road trip, moving every few days.
I'd get a huge TT or park model to park at a site. No stairs, more floor plans, less cost. Towing manners are irrelevant if you're never going to tow it.
If going on the road, get a 5th wheel for the above reasons.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 06-19-2016, 07:39 PM   #15
TT's are good if you have budget constraints. Most if not all can be towed with a 1/2 ton truck and can be quite spacious too. My TT is 35' long, weighs 7300lbs dry, can sleep up to 9 people, has 2 kitchens, 2 entrances and only costs $30k.
Sent from my iPad using Tapatalk
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 06-19-2016, 08:19 PM   #16
Croaker's Avatar
Fifth wheels used to be more stable on the road. Better handling, tighter turning, more maneuverable, easier to hitch/un-hitch
Not anymore...the newer light-weight trailers with torsion suspension, large wheels and brakes, and the new hitches that mix weight distribution with anti sway. Also electric tongue Jacks and electric stabilization jacks make maneuvering and hook up no less bothersome than fifth-wheels.
Travel trailer hitches do not take up any space in the bed, require no holes drilled in the frame of the truck, and are easily towed with 1/2 ton trucks. Also, most travel trailers are not as high as fifth-wheels.
If you have a One-ton truck, fifth-wheel is the way to go.... If you have a 3/4 or 1/2 ton, stick with a travel trailer.
Croaker is offline   Reply With Quote
Old 06-19-2016, 10:57 PM   #17
I think the OP was maybe going to live in camper full time. I have had both and the fifth wheel pulls better and more storage under camper but if I was going to live in camper full time in one place I would get a travel trailer. I like my fifth wheel but the stairs will probably get me
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 06-20-2016, 12:05 AM   #18
I don't understand the stair issue? If stairs are going to get you how are you going to get in and out of any RV you have? The entry stairs are far worse than the small inside stairs IMHO...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 06-20-2016, 12:11 AM   #19
5th wheels are still more stable than bumper pulls and still much easier to hitch and unhitched. I owned a 2604ws before the 5th wheel I own now. No comparison in handling and setup/tear down.
Now, you do have a point about the TV issues..
2016 Siverback 33IK
Old 06-20-2016, 12:28 AM   #20
I go up the stairs a lot more than just getting into camper, bathroom, bed, it takes its toll. But I am not getting any younger. JMHO
5th wheel, trailer, travel, wheel
