Old 06-19-2016, 01:58 PM   #1
5th wheel vs travel trailer
I was wondering which is better 5th wheel vs travel trailer, for durability , permanent living.?
I'm considering buying a new one.
jishele is offline   Reply With Quote
Old 06-19-2016, 04:07 PM   #2
Jim34RL's Avatar
In my very humble opinion it is a 5th wheel trailer. They are built better and tend to have more living space, such as a front living room model. The fivers have more storage space and basements are bigger than travel trailers, frames are stronger with some models having12 inch tall I beams in the them. The only negative would be the cost of some 5er's being over $100,000 or more.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, 100K+miles
Jim34RL is online now   Reply With Quote
Old 06-19-2016, 04:11 PM   #3
Moderators' Assistant
bikendan's Avatar
For permanent or full time living, 5th wheels are better.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 06-19-2016, 04:13 PM   #4
Thank you, for the response , I will look at the 5th wheel,
Old 06-19-2016, 04:18 PM   #5
Is it true , I have heard that you should have few slide out on travel trailer?
Is that true on 5th wheel?
Old 06-19-2016, 04:23 PM   #6
bikendan's Avatar
Have you been in any 5th wheels or TTs with slideouts?
If you had, you'd know the answer.
Old 06-19-2016, 04:33 PM   #7
I've only been in a travel trailer, otherwise if I knew the answer I wouldn't have post, to get some opinion.
Old 06-19-2016, 04:36 PM   #8
Mr. Dan's Avatar
Originally Posted by jishele View Post
... you should have few slide out on travel trailer?
Sorry... not sure what you mean by 'have few slide out'.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 14; booked = 28
Old 06-19-2016, 04:46 PM   #9
Positives: more storage, pulls waay easier with no sway, (even when that 18 wheeler passes you), easier to maneuver/backup. solid hitch lockup (no swaybars, or leveling bars to contend with). Usually built stronger with stiff frames. Usually storage tanks are larger. Tend to be more stable when set up. Provides justification to buy nice truck.
Negatives: Requires a nice truck, heavier, almost always a 3/4 ton truck at a minimum with diesel preferred. Hitch takes up much of the truck bed. Carrying bicycles can be a challenge, depending on use of rear of rv. More expensive, usually 25% - 50% more expensive for same living space.
Some of these are not absolutes and are just my own opinion/perception from having owned both types.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 06-19-2016, 04:54 PM   #10
Retired JSO's Avatar
My bride has bad hips so we got away from the fifthwheel to another motorhome that ate my retirement so now a TT. So far so good. No slides either.
Retired JSO is offline   Reply With Quote
5th wheel, trailer, travel, wheel
