03-07-2019, 09:57 PM
#41
Originally Posted by Witch Doctor
I say I like the small it's fresh, I hate stale, they sell this little ozone deodorizer in a little pocket spray can, about the size of a pen light, I use that in my cars now and then , if you put some of those I think it's called dry rite for a dehumidifier, and use that , you could keep your trailer smelling pretty good I would expect, once again thanks I have never heard of that before..[emoji108][emoji106]
Are you talking about Ozium?
I used that for years at my gym and at home. It works.
2017 Dynamax REV 24RB
2018 Ford F-150
03-08-2019, 03:42 AM
#42
Yes, that is the stuff I couldn't remember the exact name thanks
Coachmen M/H
Concord
2018 / 300 DSC
03-08-2019, 09:35 AM
#43
Dehumidifier
Originally Posted by Delco Bobby
Will these ozone generators get rid of the musty smell in a basement?
In cold weather my basement is fine but in summer it gets a bit stinky.
I run one of the dehumidifiers in the basement. It sits over a drain, without the catch bucket, so I never have to touch it.
I have the humidistat set in the middle of the range, so it rarely runs in the winter.
Larry
03-08-2019, 09:42 AM
#44
Larry
Yes I have a big one in the basement, it stopped any mildew growth, but not the musty smell
Coachmen M/H
Concord
2018 / 300 DSC
03-08-2019, 11:10 AM
#45
Larry
Same here but I unplug it in cooler weather and move it out of the way.
2018 Ford F-150
03-08-2019, 11:43 AM
#46
They certainly will. Best part is that the Ozone kills the "organisms" that cause the musty smell.
If you have a musty basement you more likely than not have dampness. Use an Ozone Generator to kill the smell and the mold/mildew that causes it then use a Dehumidifier that's large enough to keep the dampness from causing more smell. Keeping the air drier and occasional Ozone treatments should make your basement smell a lot better. I know what a dank basement can smell like. Grew up on a farm and the basement of the house was added on after the house was originally built. In the rainy season we actually had water running across the floor in some places of the basement.
Naturally, if you have any ground water leakage into the basement it would be a good idea to fix that too.
03-08-2019, 11:53 AM
#47
Thanks I just ordered it on my favourite shopping channel AMAZON, I'll start in my basement
Coachmen M/H
Concord
2018 / 300 DSC
03-08-2019, 12:29 PM
#48
Be sure to read the instructions.
If the house is going to be empty for a couple days give it a good dose to begin with.
03-08-2019, 12:39 PM
#49
Coachmen M/H
Concord
2018 / 300 DSC
