Need opinions...
My 2015 Flagstaff 832ikbs has an a/c leaking into the bedroom only when it runs. I am thinking the drain may be stopped up and allowing runoff to seep back inside instead of draining onto roof and flowing off the side of the rv. Anyone encounter a similar situation as this? If it is the drain pan plug, how do I access it so that I may clean it out to prevent further leakage inside. I took the plastic cowl off before I winterized it to check, but I could not see or find the drain. Any opinions or help would be greatly appreciated. Thanks for the great site and info I find everyday.
