Old 07-16-2012, 06:41 PM   #1
A/C Problem....First post...
Hello all...This is my first post and I need some help. Sorry I don't know all the lingo and everyone. But give it time and I will know some of you and figure out the lingo. Anyway... This is what I have. Dometic Model 59715.341 With wall thermo. New in 2009.
This is my problem...Best I can tell the unit froze-up this last weekend. Turned it off and headed home. Got home and plugged TT in and the compressor kicked in. Was still off on the wall thermo!? I just turned the breaker off and left it till today. Turned breaker on and the comp kicked on again. Took everything apart and all is clean and looks good. When I run the cool setting the comp kicks on and cools everything down. When I turn it to off the comp runs for about a min then kicks off hard....then starts back up about 3 mins later then kicks off after about 1 min and keeps doing this until I turn off the breaker. If the comp is running and I turn the fan to ON the comp will not turn off even with the switch turned to OFF. HELP!!! Thanks, Rob
P.S. The Tips and Tricks Forum is Great!!!
Burchtree is offline   Reply With Quote
Old 07-16-2012, 06:49 PM   #2
davidjb's Avatar
sounds like your thermostat is junk
davidjb is offline   Reply With Quote
Old 07-16-2012, 07:14 PM   #3
The thermostat on the wall? Or is there an internal thermo? How would I check to see if they are good?
Old 07-16-2012, 07:19 PM   #4
papap's Avatar
Probably just try a new one.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 07-16-2012, 07:28 PM   #5
davidjb's Avatar
on the wall
Old 07-17-2012, 10:52 AM   #6
Thanks all who helped. Bit the bullet and I am taking it in for service next week.
