Old 09-07-2014, 06:35 PM   #1
AC Filter in floor register?
Anyone ever cut AC filter material and put it in the floor register to keep junk from falling in? I thought of it yesterday while looking for screen. I was concerned about air flow if the screens got dirty, not to mention the price of a roll just to cut out 4 small pieces. Then I thought of the black spongy AC filter material. You can get a big square of it for less than a dollar at WalMart.
Just curious if anyone has tried this, and if it works well. I want to make sure the air flow through the floor register isn't restricted too much.
Thanks.
IchLiebeBier is offline   Reply With Quote
Old 09-07-2014, 06:40 PM   #2
Capt. Mike's Avatar
Thanks.
Take an old pair of your DW's pantyhose. Cut a piece slightly larger than the floor register, and rubber-band it to the bottom of the register, then re-insert the register and screw it back down. Plenty of air flow, and nothing will drop into the heat duct.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 09-07-2014, 07:01 PM   #3
Rupkin2's Avatar
In the past I have used furnace filter material. I would cut it to fit the register.
I have also used fabric dryer sheets.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 09-09-2014, 12:20 PM   #4
I have used plastic screen. I cut it to fit just a bit larger. Screw in the vent. Then trim around it. Has worked very well.
wiscoheel is offline   Reply With Quote
Old 09-09-2014, 01:12 PM   #5
Thanks for all the replies. I'm going to try the AC filter first and see how it goes, since I already bought it. I probably won't know until our Oct camping trip though. It's not cold enough to turn on the furnace yet.
Old 09-10-2014, 10:33 AM   #6
realebill's Avatar
Pk of 12. Home Depot
Sent from my VS840 4G using Forest River Forums mobile app
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 09-10-2014, 11:48 AM   #7
ceedog's Avatar
I used vent filters (like realebill) & they work fine. The accumulated dirt can be vacuumed up without removing the filter. They don't impact the furnace operation at all & seem to reduce the amount of pollen/dust in the coach when the furnace is on.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 09-10-2014, 03:53 PM   #8
I didn't see those when I was at HD. What are they made of, foam, or paper, like a home AC filter?
Old 09-11-2014, 07:08 AM   #9
ceedog's Avatar
They're made of some type of synthetic material. It's not the same as the AC filter but similar. I found them in the aisle for AC/furnace filters in HD. They near the shelf for the registers themselves.
Old 09-11-2014, 07:45 AM   #10
Thanks. I'll check them out. I need to go to HD for some other stuff anyway. I never need much of an excuse. It's one of my favorite stores.
