Old 09-26-2014, 06:06 PM   #1
AC help Dometic Salem 30 qbss
Anyone have any ideas as to why my AC won't blow cold air? I cleaned the filter didn't help, checked the fuses, flipped the breakers, check the wire that is in between two coils to make sure it doesn't freeze. No luck. What else can I check just want to be cool during the day. The fan comes on but no cool air. Furnace works fine. I have the dometic brisk air ll 15,000 btu and the 2014 salem 30 QBSS. Any help would be great.
travelnurse is offline   Reply With Quote
Old 09-26-2014, 07:12 PM   #2
BooBoo23's Avatar
Your AC may have lost its charge. I have a 2014 Puma and it also would not blow cold air, I could hear the compressor kick on but no cold. I took it back to the dealer and they replaced the entire roof unit. The service man said it was a sealed unit and could not be recharged so replacement is the only fix. Fortunately it was under warranty. It took them about an hour to make the change. When I called them about it the service manager said he wanted to make sure he had a replacement in stock before I brought it back as he didn't want me to leave it with them, but take it back home the same day.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 09-26-2014, 11:33 PM   #3
Maybe your relay control board and or thermostat may be bad
OKI Marine is offline   Reply With Quote
Old 09-27-2014, 07:51 PM   #4
fx2
I had the same issue, no charge in the A/C. Replaced under warranty
2014 Surveyor SC321BHTS
2016 Nissan Titan XD SL4x4 Cummins
fx2 is offline   Reply With Quote
dometic, salem
