Very common complaint in the Summer in warm climates. The quick test of how well your A/C units are functioning is to use a thermometer with a probe and check the inlet and outlet temperatures after running the units for at least 15 minutes.
15 to 20 degrees difference is normal for a good operating unit. If it much less than 15 degrees, ave a technician check it out. If the cooling is good, you just have an under-designed system.
