Old 07-31-2008, 07:22 AM   #11
Head Rambler
If I were you I'd take pictures of the roof and the ceiling with and without water on it. I'd also get a straight edge and check the sag inside and out and take pictures of that. Also take a pic or two of the straightedge on a flat surface. Better thing to use is a string and gauge blocks and measure the sag. Your dealer may well tell you it's normal. If they do I'd demand a letter stating that the amount of sag you have is normal from Forest River and from the dealer. Be persistant about either getting it fixed or getting the letters signed by someone of authority at FR and the dealer. Make at least three copies and send one to Forest River, one to the dealer and keep one in a safe place for future reference. Sign and date the copies and it's not a bad idea to put the VIN on them either.
Now to the fix. They can take the roof off and place a positive bowed stiffener(s) (bowed in the up direction) along side the rafter(s), jack the roof up and secure the stiffener(s) to the rafter(s) and bring the sag out that way. They'll probably want the unit back at the factory to do it.
P.S. Never admit to walking on the roof. Don't let the dealer try to put anything under the ceiling to fix the problem. That'll ruin any resale value it may have in the future.
I'm not trying to scare you. This can be fixed and as far a that goes it's not as terrible as it sounds. It may indeed be a normal amount of sag and may not be a problem at all but, a little CYA goes a long way if something happens down the road.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 07-31-2008, 05:05 PM   #12
cat1956's Avatar
I talked to Dealer today.He said for me to bring it by and leave it. He said it sounded like they may have to peel the roof back to repair it. I will take it saturday and leave it. I will post the out come after I know something. Thanks to ALL for your input.
cat1956 is offline   Reply With Quote
Old 08-06-2008, 08:04 PM   #13
cat1956's Avatar
RV dealer said it was only 1/8" slag and Forest River said it had to be at lease 1/2" before they would fix it. He said the water standing would not hurt anything and that the Dicor sealers would not let water leak around the vents. He said Sorry but Forest River was not going to pay them $6000.00 to fix a 1/8" sag.
Old 08-07-2008, 07:28 AM   #14
Head Rambler
That sounds reasonable. I wouldn't worry about it. A 1/8" sag will hold a good bit of water and it'll evaporate quickly on a flat surface like that. That's why you have no runoff. Definitely keep a check on it though. Also, keep a check on the sealant around the vents. There is also a soft rubber gasket sealing the A/C to the roof that requires periodic tightening (maybe once/year). Be careful not to tighten it too much or you'll cause it to leak. It's very soft material so the bolts are only a little more than finger tight. You have to pull the inside grill off to get to the 4 bolts.
Gotta go campin!
Old 08-07-2008, 10:32 AM   #15
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Question. Did you check the amount of sag yourself as previously suggested? It might not be the best idea in the world just to rely on what the dealer said.
dimurrrw is offline   Reply With Quote
