Old 04-25-2009, 10:26 AM   #1
Ac relay
If you look at the other topic i started titled "immediate assistance" that was my first problem. Second was i had the bypass valves turned the wrong way and while i was getting water out of the hot side it would turn cold after a second. I apparantly forget which way all 3 go in order to mix the hot with cold so after calling the dealer and figuring that out i noticed a humming noise but the ac wasnt running. I flipped the breaker fir the ac and it stopped.
Long story short was what we came up with after calling the dealer back is that a relay inside was stuck and causing the compressor to continue to run.
I gave him tge model and serial number off the ac and he ordered me one and actually has it in already so ill go get it next week when im off.
Thank goodness the temperture was cool enough that we didnt really need it but just a pain overall.
I know its a mechanical thing but still this is an 09 trailer. Sure hope the next trip works out a little smoother.
eandsphotography is offline   Reply With Quote
