Old 05-19-2016, 12:08 AM   #11
I removed that stupid shock and added the T holder to our 2304 mini lite. I absolutely hated that thing . Plus 2 of our friends had theirs ripped off by gusts of wind. The T screwed into the door, and the receiver into the trailer wall with no problems. And I am still able to open the window next to the door all the way with the T engaged.
Denny B is offline   Reply With Quote
Old 05-27-2016, 06:41 AM   #12
jeff64's Avatar
Finally got the gas shocks removed and the "T" latches installed. The front door was pretty straight forward install. The rear one took a little extra thinking to insure that the glass tilt out window doesn't get crashed if the door gets away from me and the window is open. The bumpers will make direct contact with each other and still leave 1/2" clearance between door and open glass. Neither bumper contacts the fiberglass directly. Rear latch is 6" long and the front one is standard length. There's 2-3 fingers spacing with the latch engaged, to the glass
ID:	109203   Click image for larger version
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-27-2016, 10:51 AM   #13
Looks great
Old 05-27-2016, 08:15 PM   #14
lewisb13 is offline   Reply With Quote
Old 05-27-2016, 08:16 PM   #15
Did you just screw the supplied screws in there no problem?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Old 05-28-2016, 06:48 AM   #16
jeff64's Avatar
I did. Use 1/8 drill. Use tape caulk from CW. under plates. As others have said, tighten VERY gingerly, you are going through 1 layer of fiberglass. Don't strip the threads! The caulk will ooze out around the plates after a bit and you can retighten. Again, a light touch on the screwdriver! Trim excess caulk with xacto knife,using care not to score fiberglass.
door
