Old 05-16-2016, 12:09 PM   #1
Adding T Handle Door Holder?
I've been wanting to add one of these for a while. Not sure why but my door has a shock on it and it can only open 90 degrees. The shock is so powerful the door goes flying out of your hand and it flexes the whole door jam. Anyways has anyone ever done this before? My big question is can I just bolt this in anywhere or am I looking for a stud or something? Super nevous about drilling into my brand new camper.
Sent from my SAMSUNG-SM-G900A using Tapatalk
lewisb13 is offline   Reply With Quote
Old 05-16-2016, 01:27 PM   #2
Fulltime family RVer
Why not also remove the shock on the door?
Old 05-16-2016, 01:37 PM   #3
jeff64's Avatar
I agree. I've got them, just haven't done the install yet. I'm not real wild about the gas shock anyway and the sweep seal wear is bound to happen. I'd be interested to hear about the locating the fixtures too
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-16-2016, 01:44 PM   #4
Oh I will. Just don't want to take it off there until the t handle is installed. I've already taken it off just to swing the door wide open, and it would definitely put a hole where the door handle would hit the side of the camper.
Old 05-16-2016, 02:04 PM   #5
dmchapman's Avatar
I thought about that on my trailer, also. On mine the door would contact the glass if the window was open so it would need some kind of strong stopper to limit the door travel.
dmchapman is offline   Reply With Quote
Old 05-16-2016, 02:06 PM   #6
Just A Member
EDABEUT's Avatar
I have installed those on my snowmobile trailer to hold the doors open. I just mounted it where I wanted it on the door and then lined up the latch portion on side of trailer marked and drilled.
I wanted to add a thumb latch to a storage door on my new TT and believe it or not the dealer would not drill a hole in the fiberglass door for me. Said they did not have the proper tools and that they have seen the fiberglass crack before. I just installed it myself last week and used a 5/8 inch forester bit and it drilled thru it like butter. No problems.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 05-16-2016, 02:18 PM   #7
You can pretty much mount those anywhere as long as the door swings clear of other items. Predrill, short screws, and use sealant. You will need some kind of bump stop to keep the door from smashing the trailer body or a window. Mine has a plastic tube like piece that goes on one of the screws. You need to make sure the two pieces will align or you could end up with a hole in the door from the stop.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 05-17-2016, 11:53 AM   #8
Door damage
I have the shock on my Roo as well. It eventually tore part of the door frame off where it was attached. Luckily my awning support runs right behind the door when it is open so I waterproofed the hole in the door and just use bungies to hold the door open to the support. I added at small silicone button to the door where it touched the brace to keep things from scratching. I like it now much more than when the "shock" was on it.
dmeyer is offline   Reply With Quote
Old 05-18-2016, 04:22 AM   #9
Prime Member
My TT has 2 doors. One door has the holder shown above and the other has a shock.
Sent from my iPad using Tapatalk
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 05-18-2016, 12:17 PM   #10
RiverPeeps's Avatar
I had the gas struts on my door also,
The wind grabbed my door one evening as i was opening it and it luckily ripped the threads out of the end piece on the strut
So when i got home, i installed the t-handle your photo shows
I mounted mine just above the lower seam rail on the fiberglass. I predrilled small guide holes and didn't
over tighten the mounting screws
My door now covers one of my outdoor speakers, but doesn't really affect it too much.
I love being able to open my door fully
07 Silverado Classic 2500 HD
15 Flagstaff 26fkws Emerald Edition
RiverPeeps is offline   Reply With Quote
door
