Old 02-18-2018, 09:26 AM   #1
Wolverine 1945's Avatar
Adding TPS to a Sunseeker ???
Am going to be looking into adding a Tire Pressure Reading System to our Sunseeker,,, wondering if any Sunseeker owners that have done this have any advice ??? I am guessing that maybe first I would have to add extensions to the existing valve stems after removing the extension that are there ???
Any Help would be greatly appreciated !!!
Wolverine 1945 is offline   Reply With Quote
Old 02-18-2018, 11:14 AM   #2
Wandering's Avatar
I have the TST 507 flow thru system on my Forester. Works great, really good system and great company service. I originally attached mine to the existing extensions. I’ve since replace the cheap plastic extensions with metal ones.
Happy Campin!
Forester 2451s
Wandering is offline   Reply With Quote
Old 02-18-2018, 11:35 AM   #3
I have looked @ the TST 507,,, looks to be a good system,,, I must look @ my existing valve stems,,, seams like maybe there is a pic that would have to be removed,,, in order to be able to install the sensors ???
Thanks for your advice !!!
Old 02-20-2018, 01:26 PM   #4
Truck System Technologies Rep
TST TPMS
Hi Wolverine,
Please feel free to reach out to me with any questions regarding TST TPMS. I am always available at 210-420-0132
Thank you, and I look forward to speaking with you.
Regards,
Mike Benson
TST TPMS
210-420-0132
mbenson1234 is offline   Reply With Quote
Old 02-20-2018, 07:38 PM   #5
Sunseeker 3010DS
I have the TST 507 as well I had an issue with one of the Sensor caps and replaced it with the heavy duty model so far so good. dont forget to turn off the unit when you park it or you will kill the batteries in the sending units. I also replaces all of the stem extensions with steel and put the braided stainless steel extensions on the rear inside duels. These have a clamp that keeps the valve stem centered and secure in the opening on the rim. Fast and easy to add or remove air.
slamac is offline   Reply With Quote
Old 02-20-2018, 07:55 PM   #6
geezer with gadgets
757Dave's Avatar
Here is a thread that I started a few years ago about this subject. Great responses that helped me go in the correct direction for getting extenders, etc. Read through it and glean what you need for your situation.
http://www.forestriverforums.com/for...ers-89658.html
Hope it helps!
Happy travels...
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
757Dave is offline   Reply With Quote
Old 02-21-2018, 09:20 AM   #7
Hope it helps!
Happy travels...
Thanks Dave !!!
Old 02-21-2018, 09:49 AM   #8
geezer with gadgets
757Dave's Avatar
Originally Posted by Wolverine 1945 View Post
Thanks Dave !!!
You are welcome!
sunseeker
