Old 01-08-2009, 08:03 AM   #1
Advice on winter heating using Aquahot and ?
Hi all:
We have an 04 Tsumani with an Aquahot heating system.
I plan to drive from FL to IN in a few days. I'll be parking it at our place in IN and it will be plugged in. It can get down to zero degrees there.
My questions are: Will the Aquahot be enough to keep everything from freezing or should I add other heat sources? If I add other sources, where should they go? Should I forget this nonsense and just winterize the coach?
It will be there for about a month and then will be headed South again hopefully to a job site. With this in mind, I'd rather not winterize it for just a month.
Thanks for the help!
Ken
Luvdiving is offline   Reply With Quote
Old 01-08-2009, 09:58 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
If you're going to park it for a month you'll be using quite bit of propane for your Aqua-Hot or is it electric as well? You may want to contact a dealer that sells the Tsunami for some guidance. Here's a link to a review for your coach. It explains some about the Aqua-Hot in the article. You may just want to blow out the lines rather than adding anti-freeze for a short period of time. Good luck! Charlie
http://www.fmca.com/fmc2004/novmag/coachfeature.asp
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-09-2009, 12:31 AM   #3
Just a little weather info for you it is suppose to get to zero by tuesday 1/13/09 in Indiana
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 01-09-2009, 06:05 PM   #4
Electric/Diesel Aquahot system
Hi Charlie:
Thanks for the help. It's an electric/diesel combo. I'll be right next door in the house to keep an eye on it to make sure the power doesn't trip off and burn up all my diesel.
Luvdiving
Old 01-10-2009, 08:11 AM   #5
cfsoistman's Avatar
Originally Posted by Luvdiving View Post
Hi Charlie:
Luvdiving
Glad I could help. That sounds like a nice set up and probably keeps your coach nice and warm. Have a great day! Charlie
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
