Does anyone use the eaz lift wd hitch ,it was offered on a deal i'm trying to put together,Its for a 2306 minilite , tv is 2002 tundra ex cab v6..just asking ?
The dry tongue weight is listed at 356#...could approach 500# when fully loaded. I'd recommend a W/D hitch with integrated sway control. You'll need some type of sway control for the near 24' camper.
We use the Equalizer E2 WDH with a 2002 v8 Tundra 4x4 on smaller TT. (works well). Be careful on loading the TV bed as not much payload available. Dave is right the tongue with hitch head/battery/full propane will be 500 minimum. Does the 2306 have Murphy bed?
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
The murphy bed adds weight to the tongue wt. (partly due to sofa frame) i.e. a 2304 has 551 lbs. I think with murphy bed the 2306 could have tongue wt closer to 600 lbs. You might be very close to TV GVWR of the 2002 Tundra. My ETC also has murphy bed and fully loaded is just under GVWR of 6036. This is something to watch for as payload is used up quickly with TV loaded ready for camping. Trip to scales will help alot.
Roy & Jean
Prodigy P3, E2 WDH
