Old 02-27-2015, 07:20 PM   #11
DougP47's Avatar
I put the TLC with remote control about 3 years ago. I would do it again if I needed them. Easy install and can adjust air pressure while on the road. You would be surprised how much a few pounds can chnge a ride.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 02-28-2015, 12:29 AM   #12
1l243's Avatar
I have AirLift 5000 on Ford F250. Did not get on board compressor. I ran airlines from each bag that exit near rear license plate. I use Craftsman hand held battery air compressor. Did not see need for on board air compressor. When I tow the Rig 55lbs. When I don't tow 15lbs. I never adjust it once aired up...
1l243 is offline   Reply With Quote
Old 02-28-2015, 12:52 AM   #13
Crockett's Avatar
Firestone...a little more money but traditionally the best. Saw one bag hammered many miles deflated on a class c, before the internal snubbers. Fixed the air line and reaired perfect. Only had one issue on a lifted pickup with the no- drill bracket. It kept getting bent up. Had to beef the bracket twice. I love the old 2071 brackets best...
Crockett is offline   Reply With Quote
