Old 08-04-2016, 03:08 PM   #1
Air Compressor Question
I'm looking for an Air compressor that would air up my RV tires while on the road and also I could use to blow out the lines when winterizing it in the fall. I've been looking at Viair 40047 400P-RV Automatic Portable Compressor Kit
I cannot find anything that will tell me that I can regulate the air pressure so as to not damage my water lines. For you experts out there - will this compressor do that?
Thanks,
Todd
toddlafond is offline   Reply With Quote
Old 08-04-2016, 03:11 PM   #2
nomad297's Avatar
While the VIAIR is an excellent compressor, it won't give you the volume you need to blow out your system for winterization. You need a compressor with a tank for that. I have both.
Bruce
Old 08-05-2016, 01:40 PM   #3
I have the ViAir 300 portable and it works great on the road for tires, air bags on my TV, etc. I do no think any of the portables would have enough air to blow out lines. I have a full size compressor at home for those types of uses. The portables are great at what they are designed for though. Never leave home without mine.
jmck1737 is offline   Reply With Quote
Old 08-09-2016, 05:51 PM   #4
Swaggler's Avatar
I have a VIAIR 450P. One of the best purchases I ever made. I recommend VIAIR to anyone looking for a good quality portable unit. It cannot be used to blow out the lines though. You need a compressor with a holding tank for that.
JaL
Swaggler is offline   Reply With Quote
Old 08-09-2016, 06:12 PM   #5
I have a portable, Kobalt 3 gal air compressor from Lowe's. It's 110V that pressurizes up to 155 lbs. and the output pressure can be adjusted down for various applications. I usually blow the lines out by adjusting the pressure down to 30-40 lbs. Haven't had a problem yet blowing apart plumbing fittings.
gfarmcafe is offline   Reply With Quote
