Old 08-05-2012, 11:39 PM   #1
kicker0927's Avatar
Air conditioner runoff....where does it go?
I have a 2008 Wildwood that is currently not leveled yet. It is leaning slightly to the left and the A/C condensation is running off the left side of the trailer and dripping on my stovetop vent housing casing. I was just wondering, when my trailer is leveled, where is all the condensation going to go? Will I need to worry about leaks because of it???
kicker0927 is offline   Reply With Quote
Old 08-06-2012, 12:45 AM   #2
The AC condensation runs out on the roof of the trailer, either side of the AC. Now where it goes, depends on how level the trailer is, but it will go downhill. As for leaks, always worry about leaks, more from rain than AC. Caulk yearly, or at least inspect yearly, if not more often.As for the stove top vent, most are plastic now, if yours is, it won't corrode.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-06-2012, 05:58 AM   #3
Herk7769's Avatar
The camper can be "slightly" tilted towards a "preferred" corner for the run off.
Just DO NOT over do it. Water will go downhill; even slightly downhill.
HAM CALLSIGN - KC3FFW
Old 08-07-2012, 04:57 PM   #4
If it is like mine it will go to the passenger side and drip on you whenever you go to enter or exit the door.On mine this is where FR decided to put a seam in the awning rail and it drips right there ,very irritating..
Tbonz is offline   Reply With Quote
Old 08-07-2012, 05:09 PM   #5
A dab of caulk will fix that.
Len & Cheri is offline   Reply With Quote
Old 08-07-2012, 05:38 PM   #6
I have tried more than one dab and it still leaks even used seam sealer on the awning..
air conditioner
