Old 05-27-2016, 08:05 AM   #1
mnwild58's Avatar
Air/heating
Well everything is well until I turned on furnace to take the chill off the morning air, the a/c comes on in furnace mode anyone run into this problem with their forest river campers?
mnwild58 is offline   Reply With Quote
Old 05-27-2016, 08:19 AM   #2
Pickin' & Campin'
Very well documented.
Set the fan setting on the thermostat to Auto.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-27-2016, 08:28 AM   #3
mnwild58's Avatar
Well that's a good answer but thus t-stat is one of the newer ones!
Old 05-27-2016, 08:38 AM   #4
Pickin' & Campin'
And again I'll say... set the fan setting on the thermostat to auto.
Here are the directions taken directly from the manual for your single zone digital thermostat. Pay very close attention to the words I've highlighted in red. **HERE** is a link to the complete operating guide.
“Furnace” - Furnace Mode
In this mode there are 3 fan speed selections:
Lo - (LOW): The fan operates continuously at low speed.
Hi - (HIGH): The fan operates continuously at high speed.
Au - (AUTO): The fan will be Off.
Note: If additional indoor air circulation provided by the air conditioner
is not desired during Furnace Mode of operation, select Au
(AUTO) in the Fan Mode to shut the air conditioner fan off. If Lo
(LOW) or Hi (HIGH) is selected the air conditioner fan will continue
to operate on the selected speed.
Old 05-27-2016, 08:47 AM   #5
mnwild58's Avatar
ďFurnaceĒ - Furnace Mode
Ok, it's a case of being over analyze the case, but take two minutes to look the situation and ask for help and you will get the answer! Ta dah thx 5picker. I was overlooking that part
Old 05-27-2016, 08:49 AM   #6
Pickin' & Campin'
Glad you got it figured out!
Happy camping!
Old 05-27-2016, 08:50 AM   #7
mnwild58's Avatar
Happy camping!
No you helped me out, again thank you enjoy your weekend also
Old 05-27-2016, 09:11 AM   #8
Pickin' & Campin'
As an aside... many folks PREFER the A/C fan running in the furnace mode.
Heat rises and as such, that warm air is drawn in by the A/C fan and evenly distributed throughout the unit.
Try it, you might like it!
heating
